Arufel87 Posted September 14, 2013 Share Posted September 14, 2013 I would normally go for a land raider however IWND would make a Storm Raven a lot more durable. Opinions? My list usually goes vehicle heavy with Vindicators and Dreadnoughts. Link to comment Share on other sites More sharing options...
Iron Father Ferrum Posted September 14, 2013 Share Posted September 14, 2013 I'm still a fan of the Land Raider. The reason is that even with protection from Ceramite Plating, Skyfire requirements, jink saves, IWND, and a Techmarine inside to fix it, it's still just an AV12 HP3 vehicle. One solid hit from a lascannon or missile launcher and not only is your Storm Raven dead, so is everything inside. The Raider is tougher and losing it doesn't automatically doom everyone inside. Link to comment Share on other sites More sharing options...
Arufel87 Posted September 14, 2013 Author Share Posted September 14, 2013 True, I was only considering it because every time I have proxied a storm raven it always goes down to a lot of S7 skyfire shots rather than a load of snapshot lascannons. I thought IWND could remedy that to an extent. On the subject of land raiders I'm still stuck between the redeemer and the crusader... I often run 2 vindis and I like the extra range on the crusader but the redeemer flamestorm cannons are very tempting too! Which do you use and why? Link to comment Share on other sites More sharing options...
Axagoras Posted September 14, 2013 Share Posted September 14, 2013 For transporting units the land raider is better but for a gun platform the stormraven is king, 230 points for a flying landraider crusader but with a TL MM Link to comment Share on other sites More sharing options...
minigun762 Posted September 14, 2013 Share Posted September 14, 2013 S10 hit to all occupants really turns me off using the Raven as a transport. Link to comment Share on other sites More sharing options...
Bannus Posted September 14, 2013 Share Posted September 14, 2013 Which one do I use? Mk III - the original for larger units. Achilles for smaller ones. Link to comment Share on other sites More sharing options...
Ishagu Posted September 15, 2013 Share Posted September 15, 2013 Give the Raven a locator beacon and you can drop it's occupants off without scatter whilst zooming. Don't put anything inside it that doesn't have a decent invul though... Link to comment Share on other sites More sharing options...
tdemayo Posted September 16, 2013 Share Posted September 16, 2013 I'll echo what others have said. One airplane, by itself, or even among many tanks, will attract all the Skyfire in the enemy army. One tank among many tanks, will draw less. So if you already have lots of tanks the landraider will perform better. Furthermore, if you intend to transport things, the land raider is less risky. All that said, you might want to consider multiple Stormravens. Right now, a flying vehicle has certain advantages over a ground one in that it may target anything, but may only be targeted (effectively) in turn by a smaller subset of weapons. If you can achieve air supremecy, either because the enemy brings no air or you can kill it, you may find your air vehicles have an uncontested shooting gallery. Link to comment Share on other sites More sharing options...
Kaedes Nex Posted September 19, 2013 Share Posted September 19, 2013 People are more prepared for the Stormraven these days, I find. A Land Raider is sometimes a surprise that the opponent has not prepared for and can only take out with 1 or 2 units that you can easily stop or prevent from reaching the LR. I'd say go LRC if you want consistent firepower, a sturdy brick, and a transport, and Stormraven if you just want a powerful gunship. Link to comment Share on other sites More sharing options...
Montuhotep Posted September 19, 2013 Share Posted September 19, 2013 Land Raider Achillies with a Techmarine inside. AV 14, Smoke, Extra Armour, Ferromantic Invulnerability, It Will Not Die and repair weapons or another hull point as required. Not going to go away soon. Plus, it can haul 5 Sternguard as well should anything get too close..... Link to comment Share on other sites More sharing options...
