Firepower Posted September 16, 2013 Share Posted September 16, 2013 OK, so the Thunderfire Cannon model is 1) expensive, 2) notoriously uncooperative and 3) finecast, so I'm pretty much entirely against making the standard one. The new Stalker weapons platform is ripe for making not just one, but two Thunderfire Counts As, but I'm at a loss for what to stick them on. How would you go about building a platform, or rather what bitz would you combine to make it? Lil treads? Stabilizing legs? The treads are probably the most perplexing. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/ Share on other sites More sharing options...
Tonal Posted September 16, 2013 Share Posted September 16, 2013 Correct me if I'm wrong, but I thought the treads were the defining feature of the Thunderfire? It's being mobile and all-terrain and what have you? Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463593 Share on other sites More sharing options...
MehpistonVsTheWorld Posted September 16, 2013 Share Posted September 16, 2013 Well, in my opinion, some sturdy legs would look awesome! You could also possibly incorporate a side gunner like one of those WW2 era Anti aircraft weapons. Just my two cents. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463594 Share on other sites More sharing options...
Artemid Posted September 16, 2013 Share Posted September 16, 2013 What about just using a Rapier battery and possibly fitting a different gun? http://www.forgeworld.co.uk/The_Horus_Heresy/Legiones_Astartes/Space_Marine_Legion_Army_List/LEGION_ELITES/Legion_Rapier_Weapons_Battery?filter_reset=1 Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463595 Share on other sites More sharing options...
Chronotonic Posted September 16, 2013 Share Posted September 16, 2013 heck I have one of them and they are about the same size as a thunderfire cannon... I say use it as one... Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463640 Share on other sites More sharing options...
Firepower Posted September 16, 2013 Author Share Posted September 16, 2013 I've seen those Forgeworld platforms before. Too expensive, among other things. The beauty of the Stalker cannons is that there are two in one kit. The question really revolves around what to mount those guns on, specifically if there are any plastic kits/bits from the GW range that will work easily enough (ideally treads). I think I saw someone use Sentinel legs once. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463645 Share on other sites More sharing options...
T14 Posted September 16, 2013 Share Posted September 16, 2013 Metal TF cannons can regularly be had on ebay.Or Scratch build them:2xThunderfire lookalike barrels cost $7 from Blood and Skulls industry on ebay.Pic up a few plastic EPIC tanks and combine everything with plasticcard. Done! Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463672 Share on other sites More sharing options...
tvih Posted September 16, 2013 Share Posted September 16, 2013 On 9/16/2013 at 3:50 AM, Firepower said: OK, so the Thunderfire Cannon model is 1) expensive, 2) notoriously uncooperative and 3) finecast, so I'm pretty much entirely against making the standard one. The new Stalker weapons platform is ripe for making not just one, but two Thunderfire Counts As, but I'm at a loss for what to stick them on. How would you go about building a platform, or rather what bitz would you combine to make it? Lil treads? Stabilizing legs? The treads are probably the most perplexing. Getting two platforms done as well as two techmarines isn't cheap either - especially factoring in the Stalker weapons. Though I'll agree the TFC is oddly expensive, and indeed a bit of a pain to build. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463861 Share on other sites More sharing options...
Major_Gilbear Posted September 16, 2013 Share Posted September 16, 2013 Could you kitbash this into something more fitting for your Marine force? Seeing how both that and the Thunderfire are both based of the old Thudd Gun idea, it shouldn't be too much of a stretch to get something good-looking. Plus, 90% of the kit is there, and it's reasonably cheap (especially if you buy from somewhere like the Warstore) Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463862 Share on other sites More sharing options...
Naminé Posted September 16, 2013 Share Posted September 16, 2013 I've seen someone use Epic-scale Landraiders as treads before, maybe that could work? Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463864 Share on other sites More sharing options...
Major_Gilbear Posted September 16, 2013 Share Posted September 16, 2013 On 9/16/2013 at 8:21 AM, Naminé said: I've seen someone use Epic-scale Landraiders as treads before, maybe that could work? Way too small - I have both Epic Landraiders (all marks) and the modern 40k Thunderfire, and they are totally different sizes. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463866 Share on other sites More sharing options...
Grey Mage Posted September 16, 2013 Share Posted September 16, 2013 Id suggest an old metal 'Thudd Gun' since thats all a TFC is really. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463876 Share on other sites More sharing options...
Kierdale Posted September 16, 2013 Share Posted September 16, 2013 How about using, say, four Epic Landraiders? One at each corner. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463879 Share on other sites More sharing options...
Major_Gilbear Posted September 16, 2013 Share Posted September 16, 2013 On 9/16/2013 at 9:10 AM, Kierdale said: How about using, say, four Epic Landraiders? One at each corner. Like tracked castors? Yeah, that could work. I think that another issue to be wary of is that with some epic models (like Landraiders for example), the silhouette of the model is very distinctive, and distracts from the conversion. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463892 Share on other sites More sharing options...
facmanpob Posted September 16, 2013 Share Posted September 16, 2013 http://www.manticgames.com/Shop-Home/Warpath/Forge-Fathers/Vehicles/Product/Forge-Father-Jotunn-Heavy-Hailstorm-Cannon-1-Vehicle.html How about the Mantic Hailstorm Cannon? £12.50 each..... Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463920 Share on other sites More sharing options...
Venemox Posted September 16, 2013 Share Posted September 16, 2013 I received a Dystopian Wars model from Spikey Bits random box of randomness. I plan to TFC it up. http://3.bp.blogspot.com/-jIGcrOK2z0s/UUHg5LxOSwI/AAAAAAAAl64/GUPzna5GU7s/s320/DLBS30-2.jpg Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3463930 Share on other sites More sharing options...
Kaedes Nex Posted September 16, 2013 Share Posted September 16, 2013 Since each Stalker turret only has three barrels, you should model your Techmarine with his arm cocked back ready to hurl the fourth shell. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3464016 Share on other sites More sharing options...
Artemid Posted September 16, 2013 Share Posted September 16, 2013 On 9/16/2013 at 12:17 PM, Ultramarini said: Since each Stalker turret only has three barrels, you should model your Techmarine with his arm cocked back ready to hurl the fourth shell. On 9/16/2013 at 12:17 PM, Ultramarini said: Since each Stalker turret only has three barrels, you should model your Techmarine with his arm cocked back ready to hurl the fourth shell. Long-range Holy Orb delivery system! Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3464096 Share on other sites More sharing options...
Toothbrush of Terra Posted September 17, 2013 Share Posted September 17, 2013 Firepower, you play Templars yes? There's only one way to build a platform for your Thunderfire. Out of a pile of WITCH CORPSES! Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3465097 Share on other sites More sharing options...
Hyaenidae Posted September 17, 2013 Share Posted September 17, 2013 Core out a Cyclops demolition vehicle. In the end, though, Thudderfire Cannons are the way to go... Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3465141 Share on other sites More sharing options...
Firepower Posted September 17, 2013 Author Share Posted September 17, 2013 I took a good long look at those Thudd guns. They seem too dinky, really. Passed up a steal on ebay for one at $11. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3465153 Share on other sites More sharing options...
Hyaenidae Posted September 17, 2013 Share Posted September 17, 2013 How about the DKoK Quad Guns? Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3465159 Share on other sites More sharing options...
Firepower Posted September 17, 2013 Author Share Posted September 17, 2013 Quite sexy. Still rather pricey, but nowhere near as bad as the Rapiers. Hmm... Edit- Actually I was wrong. I was looking at the Crew, not the gun. The gun is still prohibitively expensive. Mostly because of shipping and handling, really. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3465164 Share on other sites More sharing options...
Hyaenidae Posted September 17, 2013 Share Posted September 17, 2013 Gun only, ebay. I saw one go for $20, 5 buck shipping. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3465171 Share on other sites More sharing options...
Firepower Posted September 17, 2013 Author Share Posted September 17, 2013 Really, if I could just find a decent, cheap set of properly sized tank treads to serve as a platform, the rest would be easy. But if I can't then yeah, I'll just be hounding ebay A clever way to make lil robot/platform legs would work well enough, too. Link to comment https://bolterandchainsword.com/topic/280339-thunderfire-counts-as/#findComment-3465177 Share on other sites More sharing options...
