Beating the Eldar
DannyJZuko
Edit: Also, I love this mentality of "its only two sixes to wipe out a
vehicle" considering all the whining I hear about needing 6's to hit
flyers or wound wraithguard etc.
Massive difference.
One's an end result.  The other is only the beginning in a chain of hardship.
Right at the end, 2 6's then kills *anything* (bar a LR/Mono).
Right at the start, you need a 6 to hit.  Then you need to Glance/Pen.  Then you need them to fail any saves (Not sure if any fliers can currently get saves...).  Then you need to roll a damage result.
No where near the same.
Or short version:
Bikes are about a durable as marines?
That's the short version isn't it?
But they have better mobility and far better shooting.
10 marines- 10 shots at 24", 140pts. 6.6 hits.
7 Bikes- 7 shots at 24", 147pts. 6.1 hits, including rerolls.
Pt for Pt nothing bolters better than a tactical marine, and when you add in the right chapter tactics it just looks worse for the bikers.
You pay alot for the mobility and the toughness increase, the stable platform just makes special weapons viable.
  Let's put chapter tactics to the side for now.  That right there is where the money's at.   Bikes would be a good idea if they had some rule like eldar jetbikes or Tau battlesuits - but they don't  .    It would be a very cool idea if they had heavy weapons .- but they don 't.  (tho AB do)
   What further makes the  bikes somewhat a sub par  choice  .    If you advance forward away from the main force, the eldar will just engage them with multiple units .
I think very few people will agree bikers are substandard against Eldar. In a vacuum then sure, they'll die. But they are a unit that is fairly cheap (5 with 2 Grav-guns and a combi grav comes in at just 145pts) and able to put pressure on opponents. Consider your Eldar opponent needs to decide whether to deal with the very imminent threat of bikers coming for them or your transports moving into position or your fire support hitting them consistently from afar.
Not an easy choice eh.
Indeed, I've fought Eldar enough times to know that just because they're more mobile that doesn't mean you should give up maintaining your own mobility. Give them tricksy xenos something to worry about and buy your main force the breathing space to get into position and deliver the goods :)
 Those bikes will die. And when they do, it's just an easy KP-or even worse- First Blood
This is my problem with them. Their mobility suffers because they're an obvious target for focus-firing, so they spend most of their time dodging bullets rather than dishing out the pain. Pretty much everything is good at killing them - templates, massed fire, AP2/3 shots... I'm having to hide them behind buildings until they can pop out and shoot.
They're a massively cool unit, don't get me wrong, and on paper they're devastating, but in practice a decent opponent will sweep them off the board in no time.
Those Marines will die. And when they do, it's just an easy KP-or even worse- First Blood
Especially when shot by Dark Reapers.
And now add in Special/Heavy Weapons and attack bikes. ;)
It's practically impossible to score first blood on a tactical squad- just place sarge behind a tall wall,outside LOS. The rest of the unit does congo line and you're good to go.
Garath, I'm not just going to change your quote again, but consider what you just typed.  That can be applied to Bikes as well.  And next turn you can 12" move them and do the same thing again.
Or, the Eldar use thier massive mobility to move into LoS with your Sarge...
Anyway, this discussion of First Blood doesn't really have anything to do with combatting the Eldar.
I'm just surprised that Gravs were mentioned as Eldar killers, but with mobilty/range as thier weakness, and Bike versions (which rather negate the mobility/Range weakness) just seemed to be dismissed.
Especially as a combination of Drop Pod/Bike Gravs seems to be the staple go to 'power' build for Marines now.
 Perhaps I was unclear.  You have a 10 man tactical squad that doesn't need to advance much to engage the enemy with it's best weapon - heavy weapon.
  Then you find a piece of terrain tall enought to hide a single small based model out of LOS-the sarge .  The rest od the unit moves,shoots -whatever. You can stretch the unit up to almost  30".
  All the while that sarge will keep the squad alive , and his combi flamer ready.
  Bikes cannot do that.
10 man units wasting time firing a heavy weapon at a tank are grossly inefficient in Codex Space Marines since like 3rd edition. With split fire then sure, but you limit the points you can spend on offensive weapons and units this way.
Garath, what are you trying to advocate here?
Streaching a conga line of marines out of Cover?   That's bad for a number of reasons.
Also don't forget that in order for the Marines to shoot thier Heavy, they forgo all mobilty (Snap Shots are terrible).  Unlike Bikes.
Anyone can hide units for a turn or two to try to stop First Blood.  But FB is so easy to get (Unless you plan specifically for it, like going second with a full reserve army) it's usually not worth the bother worrying about.  It's also harder to hide a Rhino, as has been mentioned.
And again, this isn't really relevant for taking on the Eldar.
It's an Eldar conspiracy to limit the Internet approved army lists that can cope with Eldar supremacy!
Nah, I just honestly dont think theyre that great. On the other hand....
Alot of eldar players dont take variety in their lists like alot of marine players dont, so if youre just fighting cookie cutter net lists all the time, then go for it.
I think White Scars chatper tactics has a lot to do with it.
Bikes that;
Are scoring
Have Scout
Have H&R
Have +1 Jink Save.
Edit: I forgot the auto pass dangerous terrain tests...
Consider the Jink save bonus.  There's been a lot of talk about utilising Cover.  Well on the move (not even turbo-boosting) WS Bikes have a 4+ Cover Save.  Just for moving.  And being relentless, why wouldn't you move them?
If they Turbo, that increases to 3+.
If you're going first, you can scout them closer, then move 12", gain a 4+ Cover save in the open and Relentlessly shoot your Heavy/special weapons of choice to full effect.
You can even finish with an Assault to tie up any return shooting, and Hit and run away form it, to carry on shooting.  With increased Strength Hammer of Wrath attack to boot.
Or you can have 10 Marines, static, in 5+ Cover to shoot a single Heavy Weapon.  Or their bolters, if you're lucky enough that your enemy moves to within 18" of you...
How does everyone feel about using drop pods to minimize Eldar mobility. Thinking of dropping in a 10-man tac with flamer and combi-flamer and a dreadnought (either ironclad w/ 2 heavy flamers or standard with ass. cannon and heavy flamer) in two drop pods on turn one right on top of some of the squishy troops.
Drop Pods will only dictate your own mobility against Eldar - and only briefly at that. Once you get disembark you're yomping across the table and I'm sure you can imagine how that could end up against the nippy Eldar and their mean guns.
I don't see it being very reliable or effective unless you can deliver a crippling strike right off the bat which seems unlikely.
Ive had good success using DPs- but as a SW force the extra specials likely make the difference there. Though, you could make up some of it using combi weapons.
Id be interested in the overall viability of 5 man squads with combi+matching special in a DP as the backbone of the force.
