Transferring Paint
So, bit of a simple question-
For those of you that use palettes, or airbrushes, how do you go about transferring paint from the GW bottles?  I've tried knives, brushes, toothpicks, cotton swabs (bad idea, that) and I have still not found a way to transfer paint from these awful little bell-pots to another spot that didn't waist a bunch of it.
I've a mind to just dump my important paints into dropper bottles, but I don't know of a way to do that effectively either :teehee:
https://bolterandchainsword.com/topic/281432-transferring-paint/
What Skawolf said. I went to a Target pharmacy and asked them for one. Best. Tool. Ever for the task. Super easy to mix ratios. For getting it into the cup on the airbrush I will usually use a little plastic pipette. Been looking for real glass ones but I cant' find any.
Yeah the fact that they have the mL pre-measured out on the side of the tube is awesome. A quick rinse with water gets them clean as well. One of my most indispensable painting tools. (you know, aside from paints and brushes :D )
When I transferred most of my GW paint to dropper bottles, I used a fairly large-sized old brush (a beat-up, old Loew-Cornell #4) as a scoop and transfer instrument… After pouring MOST of the paint directly into the bottle from the GW pot, use the brush to get more out of the pot. Load up the brush, wipe it on the inside edge of the bottle. Repeat as necessary. It lets you get those last drops of paint that are usable.
