Emperor's Furor Posted October 5, 2013 Share Posted October 5, 2013 I've never done it before but someone said it in passing and I was curious, is there a reason for doing it? Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/ Share on other sites More sharing options...
Chief Captain Redd Posted October 5, 2013 Share Posted October 5, 2013 There is a release agent that they use to get the resin out of the molds and it can still be on fw models and it can "interfere" with paint and glue. Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486463 Share on other sites More sharing options...
hisdudeness Posted October 5, 2013 Share Posted October 5, 2013 It's to clean the mold release agent used to ensure the part doesn't stick to the mold. This will also make some paints not stick to the model. Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486465 Share on other sites More sharing options...
Brother Captain Lucian Posted October 5, 2013 Share Posted October 5, 2013 You may find that the components of your kit have a slight glossy sheen to them. This is caused by the release agent that our Production team use to remove the parts from the moulds. You will need some warm water and a mild abrasive cleaner such as washing-up liquid. Simply place the parts into the soapy water and leave them to soak for 5-10 minutes, then thoroughly scrub each part with an old (and we stress old) toothbrush. This will ensure that any traces of release agent are removed, and you can then remove the parts, rinse them thoroughly and allow them to dry. The glossy release agent can prevent undercoat and paint from properly adhering to the model when it’s complete, and the scrubbing also gives a very slight abrasion to the surface of the model that aids the bonding of super glue. That would be the best explanation :) Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486467 Share on other sites More sharing options...
Emperor's Furor Posted October 5, 2013 Author Share Posted October 5, 2013 Ah cool, will do that then, thanks :) Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486472 Share on other sites More sharing options...
Iron-Daemon Forge Posted October 5, 2013 Share Posted October 5, 2013 I'd also recommend spray purity seal/matt varnish on the models before you undercoat them. It just help key in the paint, stop any of the paint coming off the model. IP Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486482 Share on other sites More sharing options...
Lucien Eilam Posted October 5, 2013 Share Posted October 5, 2013 In the old days, everything you got from Forge World would be covered in a glossy coating of the stuff, and it could take multiple washes to get rid of. Lately, everything I've bought has had the same soft, matt surface finish as Finecast, with no trace of release agent at all. Whether they've changed the resin or the process I don't know, but washing isn't always essential any more. If in doubt, give it a dunk, but if the surface doesn't seem oily or shiny, it'll probably take paint just fine. Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486484 Share on other sites More sharing options...
jeremy1391 Posted October 6, 2013 Share Posted October 6, 2013 I always just to be safe use lukewarm soapy water and a soft tooth brush to clean any resin. Hasn't failed me yet. Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486637 Share on other sites More sharing options...
KJB Posted October 6, 2013 Share Posted October 6, 2013 You're a lucky man Lucien, if anything, the models I'm receiving have even more of a glossy finish! Lets see what this next order looks like... Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486877 Share on other sites More sharing options...
Haranin Posted October 6, 2013 Share Posted October 6, 2013 I always wash. You want to inspect closely post base spray to... if there are bare patches, you need to scrub that section again. Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486940 Share on other sites More sharing options...
chaplain mortis Posted October 6, 2013 Share Posted October 6, 2013 Like the others have said you definitely need to wash them..dont be tempted to rush this stage...years ago I made that mistake on a forgeworld dread..wasnt pretty with his flaky paintjob.. I have had a few packs of the "new" resin..lovely to work with, easy to clean mould lines and a treat to wash..hoping on more like that. Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3486984 Share on other sites More sharing options...
Lucien Eilam Posted October 6, 2013 Share Posted October 6, 2013 You're a lucky man Lucien, if anything, the models I'm receiving have even more of a glossy finish! Lets see what this next order looks like... Might depend on what you're buying. My last order had a Lucius drop pod you could scrape the release agent off like wax, and a ton of infantry that's basically indistinguishable from Finecast except for a slight difference in colour. I figured the pod won't be in demand as much and had probably been sitting on a shelf for months. But they might be using a different technique or resin for small detailed models like infantry than they use for big vehicles that could have been sculpted with a trowel, like the Lucius. Link to comment https://bolterandchainsword.com/topic/281444-washing-fw-models/#findComment-3487034 Share on other sites More sharing options...
