Hrvat Posted October 12, 2013 Share Posted October 12, 2013 Though the current cultists are nice looking miniatures (much better than the old metal ones) they do not fit the theme I am looking for. So before I go and order bitz I have questions. I am wondering how well the Catachan IG parts fit with the Marauder and Marauder horsemen parts. For exaple how fantasy heads and arms fit on the catachan bodies. Also how well do Thunderwolf marine legs fit either Daemon or Warrior Juggernatus and how well do Skullcrusher legs fit Thunderwulf saddles? Cheers Link to comment https://bolterandchainsword.com/topic/281804-custom-cultists-and-legs-compatibility/ Share on other sites More sharing options...
Durus Posted October 13, 2013 Share Posted October 13, 2013 The Catachan IG and (the old footslogging) Marauders should fit together quite well. There used to be an IG regiment called the Skull Takers of Kanak, with conversions based on kitbashes of the two sets. Here's a picture of the model from GW's IG Collectors Guide, which is also made that way. Couldn't find much else on them though. Took a bit of searching (they changed the spelling of the name in the german translation of C:Armageddon to avoid confusion with a racial slur I presume), but I also found this conversion on cmon which is just made with Catachan bits with some GS kneepads. Can't help you with the Thunderwolves though. Link to comment https://bolterandchainsword.com/topic/281804-custom-cultists-and-legs-compatibility/#findComment-3493319 Share on other sites More sharing options...
Hrvat Posted October 13, 2013 Author Share Posted October 13, 2013 Thank you Link to comment https://bolterandchainsword.com/topic/281804-custom-cultists-and-legs-compatibility/#findComment-3493668 Share on other sites More sharing options...
