skawolf Posted October 12, 2013 Share Posted October 12, 2013 When using a press mold made from greenstuff what should I use as a releasing agent? Would gun oil work? or should I go out and buy something specific? I used dish soap when making the mold, it didn't work out that great Link to comment https://bolterandchainsword.com/topic/281807-releasing-agent/ Share on other sites More sharing options...
Lucien Eilam Posted October 12, 2013 Share Posted October 12, 2013 I usually use olive oil. Anything greasy that you can easily wash off should do the trick though. Link to comment https://bolterandchainsword.com/topic/281807-releasing-agent/#findComment-3493276 Share on other sites More sharing options...
Res Ipsa Loquitur Posted October 12, 2013 Share Posted October 12, 2013 Yeah, olive oil. For some reason, the cheaper it is the better it works. Link to comment https://bolterandchainsword.com/topic/281807-releasing-agent/#findComment-3493286 Share on other sites More sharing options...
Marshal Rohr Posted October 13, 2013 Share Posted October 13, 2013 Switch to legit mold release, better results, even from an epoxy mold. Link to comment https://bolterandchainsword.com/topic/281807-releasing-agent/#findComment-3493320 Share on other sites More sharing options...
skawolf Posted October 13, 2013 Author Share Posted October 13, 2013 Remington REM oil with teflon (I use the bottle as I find it better for my AR's lower, but i'm sure the spray works as well) works fantastically as a release agent BTW Just made 5 stormshields (shhhh.... don't tell anyone ) and they turned out great. Edit: I made 4 stormshields, I have 5 including the original... Link to comment https://bolterandchainsword.com/topic/281807-releasing-agent/#findComment-3493995 Share on other sites More sharing options...
Major_Gilbear Posted October 14, 2013 Share Posted October 14, 2013 I use olive oil too, but I have used chapsticks as well - these are better if you don't want to get grease absolutely everywhere! ;) Link to comment https://bolterandchainsword.com/topic/281807-releasing-agent/#findComment-3494428 Share on other sites More sharing options...
skawolf Posted October 14, 2013 Author Share Posted October 14, 2013 haha, I never thought of using chapstick. Link to comment https://bolterandchainsword.com/topic/281807-releasing-agent/#findComment-3494909 Share on other sites More sharing options...
Seleucus Posted October 14, 2013 Share Posted October 14, 2013 I simply use vaseline. I wipe a finger with a fine coating of vaseline over the soft GS before pushing it into the mould. I would always put the releasing agent, whatever you use, on the soft GS, not into the mould as it is less likely to pool into the recesses of the mould, and, therefore, less likely to reduce the detail on the moulding. This is also the case when making a mould from the original object - put the releasing agent on the GS not the object. Link to comment https://bolterandchainsword.com/topic/281807-releasing-agent/#findComment-3495016 Share on other sites More sharing options...
