Help with Word Bearers conversions
I haven't done it, but I imagine you could do it relatively easily. Cut/file down the Dark Angels and Imperial iconography, replace with push molds of Word Bearers and Chaos iconography. Also lots of painted thin wavy lines to look like script.
am not sure if the set is still sold , but Black templers had a very nice plastic set of models that fits the WB a lot . Even more then the DA one imo . I have made a WB army using a mix of space wolfs GH boxs and BT parts . They looked feral enough to feel like chaos, but with the enough the crusade/zelot feel .
I haven't used any DA bits for my WB, though I did a squad based on BT parts. After a lot of comparison and contemplation, I decided that the BT bits were easier to mix with CSM bits, and they were easier to convert too. On the other hand, Tzen has done some really cool WB using DA bits, so it can definitely be done.
I just felt that the DA marines had too much of them covered in cloth, and was worried that they would clash a bit too much with the rest of my marines.
If you check over on warseer - Rovient has a really great Word Bearer army & I think he use a few of the Dark Angels parts
http://www.warseer.com/forums/showthread.php?344133-21st-Host-of-the-Word-Bearers-Legion
I seen a lot of other Word Bearer armies using the old metal Dark Angel robe models as chosen & look really cool as well.
Hope that helps
IP
