Daemonic depression
The fact that fast daemon close combat lists can be in peoples faces turn 1? Flesh hounds going for turn 1 assaults, hounds being dirt cheap hyper effective units. Screamers turbo boosting right infront of enemy line turn 1. Wreaking havoc with mass fmc lists. Playing big squads of troops and deepstriking in soulgrinders. Fateweaver being a beast.
Rolling for lots of funny random results, being able to cast lots of spells. Powerful character models.
Excellent models, good conversion and counts as possibilities. Bright exotic colour schemes are easy to pull off. Chaos fluff is amazing. Chaos is amazing. Being a baddy is fun. Blood for the blood god. Porn for the porn god etc.
What isn´t to like? It always feels good kicking in some loyalist skulls ;).
Well I dug out my daemon codex over the weekend and read through it. I think my Slaanesh army will be revived some time soon. I really like the idea of multiple high level telepaths on the board to control half of the opposing army and scream the rest to death.
I realy liked to play screamer star , till GW made the OP SoB codex , not I no longer care .
I haven't read it yet, what about it is so op?
I believe they have a bolter that causes a perils wound on every psyker in the unit shot for each hit it causes.
Except it is a combi-shot, single shot. so once per unit per game, if the person even paid for them.
It's not like there is anything else all that great for a Sister Superior to take.  With 5 sister squad sizes now and still able to take two special weapons, I think you will find these becoming the "go to" combi upgrades for superiors and many armies will start taking MSU razorback(Immolator) spam for 4 to 6 condemnor bolters per primary detachment.  One could take a command squad with up to 5 of these but that's making a them a very specialized unit.
A basic troop squad would be 2 bolter sisters, 2 meltagun sisters and a superior with a condemnor in a Multi-Melta Immolator for 150 points  This exact same set up can be used as Celestians (Elite choice), Dominions (Fast Attack) and Retributors (Heavy) so you could easily field 5 units as an allied detachment. Add in a Canoness to lead them and you have 6 "kill psykers on a HIT to the UNIT" weapons along with a torrent of melta fire.
This is all assuming that the condemnor does not get FAQ'ed or otherwise ruled to work differently than the new current RAW.  I don't believe it is supposed to work this way but whether or not GW will actually put out a C:AS FAQ that actually addresses this is yet to be seen.
Have you read it yet jeske?
Because I have and thats not what it says. Its very poorly worded and it stilll up in the air exactly how this is meant to react with the rules.
 Psi-shock: Any unit with the Pskyer, Brotherhood of Psykers or Psychic Pilot special rules that is hit by a weapon with this special rule suffers the Perils of the Warp in addition to any other damage.
Ooooh, then it's not that bad. A unit of Screamers doesn't have the Psyker, Brotherhood of Psykers or Psychic Pilot special rules so it would do nothing, even with the heralds in front. The unit is hit, the heralds are allocated wounds...but the unit is still called Screamers of Tzeentch, no matter how many heralds joins it...
Don't forget to bring a Soul Grinder! :D
Od.
Well if it says that, the Brotherhood of Psykers rule dictates the focal model for the unit takes the hit, surely.
Anyway, I've always wanted to start a Daemon army. Predominantly Slannesh themed with psychic trickery from Tzeentch.
But if I had the true modeller gift I'd make a themed army on a circus of the damned (guess the theme original source).
Such a theme can grant you a new lease on an army.
Yea, there's no real debate on it, unless you just don't read the rules.
"Any unit with the Psyker, Brotherhood of Psykers, or Psychic Pilot special rules that is hit by a weapon with this special rule suffers the Perils of the Warp in addition to any other damage."
"If the unit suffers the Perils of the Warp, or any other attack that specifically targets Psykers, it is resolved against the character, if there is one, or against a random, non-character model in the unit, if there is no character."
"While an Independent Character is part of a unit, he counts as part of the unit for all rules purposes"
So a brotherhood of psykers has 1 dude suffer the effects. Big whoop.
Since he counts as a "screamer", he isn't hurt by the shot.
  • 2 weeks later...
The ebook has been updated and teh iBook will follow soon.  The psi-shock rule has been changed.  It is back to the GK or White Dwarf codex version.  If it causes an unsaved wound on a psyker, the target takes a perils of the warp.
So .... you will never see a condemnor bolter on table again ;)
