Condemnor Boltgun?
Fibonacci
Considering how hard it is to convert metal sisters, I'd wait for a FAQ before chopping arms off, though... I haven't seen the AS codex yet, but I understand that the wording implies a hit causes a peril of the warp on the whole unit? Yet, the profile in Codex:GK is different. Usually, GW tends to bring rules towards greater uniformity...
It should not be terribly difficult to add crossbow type things to the existing Sisters models without any drastic modifications.  They have a sort of rail that juts out from under the barrel and the hand is usually far enough back that there is enough room to attach a small crossbow to the bottom.
My WFB army is Dwarves, so I have tons of the crossbows cross pieces left over from the Thunders kit.
My plan was to simply attach them to the superior’s bolters.
It isn’t a cheap solution if you don’t already play Dwarves.
But you may check at your LGS to see if anyone plays Dwarves and has some of those bits to spare.
Or if you are in Dallas / Ft Worth... I might be able to help you out.
Thanks for the offer.  I'm in Odessa, TX a mere 400 miles west of there.
I have a friend that plays Dwarves, or at least he used to but no one out has played since sometime during 7th edition.  I should be able to come up with 3 or 4 and that would be plenty for what I want to do.
