removing space marine arms
Pull it off, break it off, or cut it off with various implements are all possible solutions.
I just de-armed about 13-14 Marines the other day with various levels of paint damage, but nothing a quick paint touch up can't cure.
With A Hammer! On a more serious note simply pulling the arm off if the glue is weak enough, or gently attacking it with a sharp blade to weaken the glue should allow it to come off without damaging the rest of the model. I've changed the arms on a large number of marines so let me add once you get the arm off scrap and file off as much of the old glue as possible if any is left. Otherwise it takes forever to set.
Be careful though, I did this to a marine the other day and both arms, a shoulder pad, and the head all ended up coming loose. Nothing a little clean up and glue can't fit but figured I'd mention it.
WITH A HAMMER! i think the hammer of the emperor would strike me down for such heresy. but i tried what you said and it worked so thanks.
superglue or plastic glue?
plastic glue will have bonded the parts and a knife will likely be the better option.
superglue is more brittle and a bit of teasing/pulling might work. I've also head that putting the model in the freezer for a while can help but not tried this myself.
for pulling a apart a landraider last night I resorted to running a knife down the joins, using my modelling tool (which I embedded in the back of my thumb holding the model) to leaver up and separate bits and a TV remote control for a bit of percussive assistance. I do not recommend the last option, you end up changing the channel by accident.
Is it painted?  If not, and superglue was used, then you can soak the model in Superclean (from automotive aisle at Walmart) and it'll make the bond brittle, and very easy to pop off without damage.  It'll remove the paint extremely effectively, however, so don't do this on anything you want to try to keep the paint in good shape on.
V
The other way if you have used citadel glue that melts the plastic together is to get a pair of wire cutters and put them under the arm.
slowly close the jaws so it starts to cut through the plastic where its joined and you will find the force exerted on the upper part of the arm will push it away from the body breaking the join without too much damage.
it melts plastic?  i thought that that that only happened when you had like really thin flimsy plastic.   and the glue im using is gale force nine premium-instant  hobby glue.
Yes, that is the primary purpose for a polystyrene cement type adhesive.
IT softens the plastics and blends them together into a new whole, as strong as each piece was before.
There are NO chemical debonders for this type of 'glue' - because it ISN'T a glue, but a solvent that is DESIGNED to soften plastics.
Any chemical solvent capable of breaking the bond, will by its very nature, destroy plastics - since you don't dissolve the "glue" bond, but rather the bond itself.
Pretty much Plastic model glue welds the plastic pieces together. It's what it's made to do.
No offense intended, but I'm dumb so I sat there for a few minutes trying to figure out what you said. My apologies.
