Spaced Hulk Posted November 16, 2013 Share Posted November 16, 2013 Just a quick question: should I be watering down Nuln Oil (and other washes) in the same way as normal paints? I've been using it straight from the bottle and it seems to be producing a shiny effect. Is that normal? Thanks in advance Link to comment https://bolterandchainsword.com/topic/283402-nuln-oil/ Share on other sites More sharing options...
ferrus Posted November 16, 2013 Share Posted November 16, 2013 If the washes are leaving a glossy finish all you need to do is give them a good shake before you use them, I use mine straight from the pot Link to comment https://bolterandchainsword.com/topic/283402-nuln-oil/#findComment-3523705 Share on other sites More sharing options...
deathspectersgt7 Posted November 16, 2013 Share Posted November 16, 2013 YUP!shake shake ,shake that bottle!!! Link to comment https://bolterandchainsword.com/topic/283402-nuln-oil/#findComment-3523716 Share on other sites More sharing options...
Spaced Hulk Posted November 16, 2013 Author Share Posted November 16, 2013 Cheers guys Knew I was doing something wrong Link to comment https://bolterandchainsword.com/topic/283402-nuln-oil/#findComment-3523727 Share on other sites More sharing options...
DarkMark Posted November 17, 2013 Share Posted November 17, 2013 A dab of Lahmian medium will remove any shine from the finish. Sadly, some washes do have a glossy finish that you may not want. Link to comment https://bolterandchainsword.com/topic/283402-nuln-oil/#findComment-3524151 Share on other sites More sharing options...
