Necron Death Ray
Morticon
What does snap firing have to do with any of the questions asked...
On question 1 yes it can because theres nothing stopping it much like jaws of the world wolf picking guys out of CC
for question 2 id say the first point has to abide by the 45 degree hull mounted arc but you can drag the other end in any direction
You can only shoot into combat if you have a specific allowance to do so. So no you can't Death Ray or JotWW into combat.
Now if you shoot a unit that happens to be right next to a unit in assault you could still end up drawing a line through the assault. Again just can't 'target' the assault units.
Lysere- the "targeting" of a unit is a 5th ed throwback. It pops up in all these debates online.
6th ed no longer says you may not "target" a unit in combat it says: "a unit may not shoot at models in close combat"
Im happy to accept that as a compromise - but, is it actually the case?
The principle is the same for goodness sake.
You cannot shoot at models in close combat, tracing the line of a Necron Death Ray through them is shooting them, whether they are the actual target or not.
If I recall one end of the line scatters. Blast weapons can end up landing on units in an assault due to scatter. I believe things that draw a line or some such that has an end that scatters could arguably do the same. Would take a lot of luck though.
You nominate the end point within 3D6 so there is no random element as to where the end of the line is, you choose where it will end.
Nominate Start point - Roll 3D6 - Nominate End point
Ah that's right, in that case no you couldn't shoot at the assault. I just remember that there was some dice rolling involved for randomness, couldn't remember the rules.
