Dosjetka Posted November 19, 2013 Share Posted November 19, 2013 Hello! I have been looking at a couple of Stormravens that have been modified with the Chapterhouse Studios extension kit and they look really good. However, before giving money to a company that I have no experience with, I thought I'd ask the community here how their dealings with the company went and how good the quality of their kits is? I heard somewhere that the quality could vary quite a bit between kits, and I'm wondering if this has changed at all? Cheers, Ludo Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/ Share on other sites More sharing options...
Bung Posted November 19, 2013 Share Posted November 19, 2013 A friend of mine ordered that kit for his Raven and was satisfied. We are here in Germany so shipping needed some time but was still ok and the kit fitted without problems. Anyways get that Kit or a Storm Eagle from Forgeworld everything loos better than the unmodified Brick Raven. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3525863 Share on other sites More sharing options...
Dosjetka Posted November 19, 2013 Author Share Posted November 19, 2013 Great, thank you Bung! Since I'm in Switzerland, shipping will probably take approximately the same amount of time (a couple of weeks or so?). Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3525870 Share on other sites More sharing options...
etzchayim Posted November 19, 2013 Share Posted November 19, 2013 I'm living in South Korea (yes, pretty wasteland for Miniature), still I ordered that upgrade kit. Resin quality is fine, not number one but can handle that not so hard. In my case, two week and few days (work day only). That not bad, Ludovic. Just be brave and Try! Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3525891 Share on other sites More sharing options...
Dosjetka Posted November 19, 2013 Author Share Posted November 19, 2013 Thank you for your reply, etzchayim! I'll give it a try as soon as I can get the money for both the Stormraven and the conversion kit :) Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3525895 Share on other sites More sharing options...
BrotherCaptainArkhan Posted November 19, 2013 Share Posted November 19, 2013 There's a Stormraven in my log in my signature which has had the Chapterhouse treatment; I would say go for it but be aware that firstly, the Chapterhouse resin is very, very brittle indeed, and is much more prone to snapping than probably any resin you've used before. It is also a very imperfect cast; I don't just mean warping and twisting, it may actually be uneven in places or lacking segments (I had to add about 5mm of floor panel to make the bottom section even, and it's still not perfect). If you're happy putting in some work to make it look acceptable then go for it. And they do take a while to send stuff, I was in the UK and it took them somewhere in the region of 4-6 weeks to deliver. Hope that helps. Arkhan Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3525951 Share on other sites More sharing options...
d3m01iti0n Posted November 19, 2013 Share Posted November 19, 2013 Its a pretty decent third party kit. Generous application of super glue and a little bit of green stuff and mine is solid. It was a minor hassle to assemble but very worth the results. Looks a lot more impressive on the table next to standard Ravens and will get a lot of compliments. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526037 Share on other sites More sharing options...
elmo Posted November 19, 2013 Share Posted November 19, 2013 Service was good. I'm in Germany and had to visit the local Zollamt to collect it and pay the import duties. Very happy with the quality and really improves the storm budgie. See my signature. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526129 Share on other sites More sharing options...
Olgerth Istaarn Posted November 19, 2013 Share Posted November 19, 2013 Chapterhouse has good customer service, and the kit itself is quite good. It is indeed a minor hassle to tack on, and will require greenstuffing. Some panels may have substantial flash on them so be careful when cutting. Overall I'm very happy with the end result, it makes the SR into a rather large and impressive bird. You may also want to look into jury-rigging a chin mount for the lascannons/assault cannons/plasma cannons, because once you mount the extension kit, the turret on the roof looks VERY out of place. The kit ships with a handy hatch that covers the hole where the turret sits. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526139 Share on other sites More sharing options...
zxyogi Posted November 19, 2013 Share Posted November 19, 2013 Good delivery time! Only problem was the casting,thin in places so much so you could put your finger through it! Plenty of warpage....put some effort in and it makes a good kit. Shame its not 100% from the off! Oh......how did that happen?....... Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526161 Share on other sites More sharing options...
BrotherCaptainArkhan Posted November 19, 2013 Share Posted November 19, 2013 ^That's a really nice model, dude. May I ask how you attached the wings? I ended up magnetising mine and they're at a different angle, which I prefer, but yours look like they fit right on with no problems. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526204 Share on other sites More sharing options...
Raztalin Posted November 19, 2013 Share Posted November 19, 2013 I've ordered a few of these upgrade to the UK, delivery was as expected from the States, so no issues there (no import duty either), the quality was good, a small amount of tidy up needed, but what resin kits don't!? ;) Would recommend the use of them any day Hope that helps Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526214 Share on other sites More sharing options...
zxyogi Posted November 19, 2013 Share Posted November 19, 2013 On 11/19/2013 at 5:15 PM, BrotherCaptainArkhan said: ^That's a really nice model, dude. May I ask how you attached the wings? I ended up magnetising mine and they're at a different angle, which I prefer, but yours look like they fit right on with no problems. Thanks! Just glued them into position,cant remember if its the stock location or the Chapterhouse fixing point. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526246 Share on other sites More sharing options...
Olgerth Istaarn Posted November 19, 2013 Share Posted November 19, 2013 Wings mount to stock attachment points. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526264 Share on other sites More sharing options...
Grotsmasha Posted November 19, 2013 Share Posted November 19, 2013 I've just ordered mine to assist in a Storm Eagle conversion, so I'll be able to give comment soon. Honda has some pics in his Custodes thread on the small hassles the kit gave him, iirc he assembled three in total. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526283 Share on other sites More sharing options...
BrotherCaptainArkhan Posted November 19, 2013 Share Posted November 19, 2013 I must have had a dodgy cast or something. They would not fit on mine without serious modification, hence the magnetisation. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526284 Share on other sites More sharing options...
elmo Posted November 19, 2013 Share Posted November 19, 2013 On 11/19/2013 at 3:30 PM, Olgerth Istaarn said: You may also want to look into jury-rigging a chin mount for the lascannons/assault cannons/plasma cannons, because once you mount the extension kit, the turret on the roof looks VERY out of place. The kit ships with a handy hatch that covers the hole where the turret sits. Or you can play around with the layout a little like this and keep the air intake forward so the turret does not look out of place. http://i814.photobucket.com/albums/zz66/jonbrooks_photo/B%20and%20S%20WIP/Storm%20Raven/CIMG2253.jpg On 11/19/2013 at 4:21 PM, zxyogi said: Its nice to see that someone else ignored the GW instructions and glued the tail elevator the other way around to look more aircraft like - looks much better Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526406 Share on other sites More sharing options...
Dosjetka Posted November 20, 2013 Author Share Posted November 20, 2013 Thanks for all of the feedback and advice everyone, it's much appreciated :) Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3526708 Share on other sites More sharing options...
Nym468 Posted November 20, 2013 Share Posted November 20, 2013 Both of my Stormravens have the extension. The kit is decent, both required a little green stuff at the seams but overall it made the Stormravens a much better kit. Shipping was pretty quick for me. I also used their alternate top turrets which look a lot better than the stock servitor turret. Pictures are in the build thread below. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3527326 Share on other sites More sharing options...
Red Fury Posted November 20, 2013 Share Posted November 20, 2013 I never did finish it, but here is some of what I did. Turret, magnets, nose and tail. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3527338 Share on other sites More sharing options...
Grotsmasha Posted November 27, 2013 Share Posted November 27, 2013 Having received my CHS ext kit yesterday, I set about assembling it last night. Honestly, it was a bit of a pig. Figuring I'd built both halves then attach them, I started by attaching the rear plate to the sides, then the top, then the bottom, then to the SR kit. There's a few things I'd do differently. Firstly, I'd attach the SR side pieces to the ext kit sides by pinning them (some hot water may be required to line up at the bottom), I would also do any gap fill, and there will be some, on the sides at this stage. Then I would attach the SR front floor and rear wall/hatch plate. I recommend pinning the walls into the leg stand bit for a little more durability, just be aware of where to pin if you're modelling the legs extended. I found the ext kits floor piece to be, well useless. I turfed it and glued in a cut to size piece of 2mm plasticard. It was at this stage I decided I'd paint the interior and just dry fitted the roof. I placed the SR top piece then found that the ext kit piece would need trimming to make it sit right, just a little too much overhang on one side. IMO, although the kit isn't perfect and requires a little work, it's only $25ish, and makes the SR a lot better, I consider the kit to be worth the money. http://i1276.photobucket.com/albums/y464/Grotsmasha/Storm%20Eagle/IMAG0246_zps28f1cb40.jpg http://i1276.photobucket.com/albums/y464/Grotsmasha/Storm%20Eagle/IMAG0245_zps0edf3c4f.jpg http://i1276.photobucket.com/albums/y464/Grotsmasha/Storm%20Eagle/IMAG0247_zpsc1d635ab.jpg http://i1276.photobucket.com/albums/y464/Grotsmasha/Storm%20Eagle/IMAG0249_zpse729b308.jpg Cheers, Jono Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3532037 Share on other sites More sharing options...
The_Chaplain Posted November 27, 2013 Share Posted November 27, 2013 Hmmmm, maybe it looks better when all the sides are evened out, and gaps filled- but those panel details are kinda...ugly. Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3532068 Share on other sites More sharing options...
Grotsmasha Posted November 27, 2013 Share Posted November 27, 2013 On 11/27/2013 at 1:34 AM, The_Chaplain said: Hmmmm, maybe it looks better when all the sides are evened out, and gaps filled- but those panel details are kinda...ugly. The engines and wings cover most of it. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3532069 Share on other sites More sharing options...
zxyogi Posted December 2, 2013 Share Posted December 2, 2013 Yours looks to be far better than the kit i received! Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3535908 Share on other sites More sharing options...
The_Chaplain Posted December 3, 2013 Share Posted December 3, 2013 What was wrong with your kit zxyogi? Warped or lots of casting bubbles, etc? Link to comment https://bolterandchainsword.com/topic/283531-stormraven-chapterhouse-studios-extension-kit/#findComment-3536169 Share on other sites More sharing options...
