The beacon of Maccrage and sotha....
jeremy1391
It's the common theory running around at the moment.
EDIT: Although a counterpoint would be why couldn't the Astronomicon do the same? Both are beacons after all and we have no evidence that the Pharos is any brighter than the Astronomicon.
The astronomicon is actually doing the same. That's why the Tyranids are rushing to Terra.
I know. But who is to say that it wasn't originally the Astronomicon that attracted them? IIRC, every fleet that is on a map is usually coming in from the south east in a general northwest direction. How do we really know it was the Pharos and not the Astronomicon that attracted them when the Astronomicon has been pumping out power for far longer?
Because that would be a funny coincidence if the Tyranids came to Maccrage first instead of directly getting to Terra, if it wasn't to devour and shut down the Pharos.
I'd say they came for the Pharos in the first place, and then came back for the astronomicon.
Except the Pharos isn't at Macragge. It's like a laser pointer. It shines the light somewhere else. It made Macragge visible to those who didn't have access to the Astronomicon, no more, no less. It did not move to Macragge and we don't even know if it will survive the Heresy.
And that's something else to consider. The Pharos only illuminates a specific place. The Astronomicon actually calms the warp to some degree, making it safer to travel while also illuminating a decent portion of the galaxy, not just a specific place.
Hmm. Idea for speculation. Kind of using jeremy's as a basis.
What if the Astronomicon actually did let them notice us when it was first made. After all, the thing is bright enough to light up a whole galaxy. Then when the Ruinstorm blocked out the Astronomicon, the same thing that blocked it out, also served as a shutter of sorts. So when the Pharos shined its light from Sotha onto Macragge, even though it was infinitely smaller, it bounced off of the shutter and temporarily lighted a path for them to follow. And then when the Ruinstorm fell, they had their lighthouse to head towards.
Maybe. But the Astronimcon doesn't reach to the galaxy's edges. But with the vagaries of the warp the Hive Mind might have seen it. I personally see the Tyranids as one of the Old One's end games.
We have no evidence that the Pharos does either. So far, the only thing we've ever seen it do is just make Macragge visible to those within the Ruinstorm.
Except the Blood Angels see it from the Signus system. And it led them there brighter than the astronomican led to Terra.
I'm throwing around the assumption that the tyranids only came across the warp once they assimilated enough of the galaxy's psyker genome, ie I'm putting forward psykers and the _knowledge_ of the warp is restricted to the Milky Way. With the Macragge Beacon being of more... conventional origin, it would tie in tightly were it ever know that the 'nids started towards the galaxy during the heresy timeline, or perhaps whenever the beacons were last used (intra-galactic space-time shenanigans).
Edit: I'll bite the off topic bait and say I view the tyranids as a completely alien threat, alien to the Old Ones, alien to the galaxy at large. Both thematically and narrative wise, it's reassuring that there's still a chance empire politics, worship and krump quotas can be put to the side line when spacefaring species are reintroduced to the concept of the foodchain. I hold no remorse for that earlier pun.
There is some VERY old fluff that had the Tyranids created by the Old Ones to fight an enemy they could not defeat a galaxy or two over, then with this enemy defeated the Tyranids turned on the Old Ones, and are now back-tracking along the Old Ones path to sate their insatiable hunger.
That piece of fluff iirc is from the genesperm/ half Eldar Tigurius/ Sigmar was a missing Primarch era.....
Cheers,
Jono
Signus is in the Ultima Segmentum. Which is the Segmentum currently cut off from the Imperium.
Then we have another continuity fail ala Outcast Dead, as the Blood Angels weren't being impacted by the Ruinstorm when they left Signus Prime. Back on topic, if the beacon is what triggered the Nids, and what we've seen is really just a scout force, M49 is going to be a reaaallllly bad time for the galaxy.
There was a really small tidbit in a 5th Ed. Codex (maybe rulebook?) That said the Munitorum needed to increase manpower by 500% to deal with the projected full force of the incoming Tyranids....
Outcast Dead was also concurrent with Istvaan V.
And yes, it would be a fail, but on James Swalow's part as Fear to Tread(which was printed after The Outcast Dead) has Signus starting before the Imperium is aware of the Heresy(but after Istvaan III) and "ending" after Betrayer. The events of the book even has the IX Legion being cut off from the rest of the Imperium.
I'm pretty sure the time dilation of the Signus system was explained or alluded to in Fear to Tread. No book to hand though, so if anyone has material that can refute that, I'd be happy to be wrong.
It might be, I don't recall at this moment. Just that when it begins, Sanguinius still believes Horus is loyal. Which could be any decent amount of time between Istvaan III and V. When the novel ends, Erebus is getting his face cut off, which is after Betrayer, but before Vulkan Lives. IIRC, it was something like they perception of time within the Signus Cluster was sped up so two years happened while the rest of the universe went from the starting point of the Signus campaign to when Erebus ran away from Khârn one year after Istvaan V, which would also be after the Ruinstorm was completed. And then traveling from Signus to Macragge, they advanced to the third year of the Heresy, although I can't recall if they were still only at their third year or if they experienced the "full" two years that would pass from the Ruinstorm's birth to the events of Unremembered Empire.
Signus suffers a warp blanket by the Slannesh daemon, uses all the bones from the local system for building the portal/church but it lessens once the daemon's gone and iirc, the BA know it's not the Astronomican.
Macragge and whole of Ultramar are under the Ruinstorm, powered by the death of a star and no doubt further enhanced by Lorgar's "Ode to Angron".
Bearing in mind the Pharos device uses the intention/empathy/desires of individuals and Guiliman's interaction with the device , he could've used it to contact one of his remaining brothers from his chosen few hence Sanguinius appearing, to meet what Guiliman wanted most.
And I'm not so sure that the Pharos device will still be around in 40K...can't explain why exactly but have the feeling something "big" will happen and it is destroyed/damaged beyond repair or Horus sees it, sends in Alpha's.....rest is Heresy
It's probab;y because Sotha was one of the fall back points for the VIII Legion after Sheol and most of the remaining three-quarters are supposed to meet there. And since Massacre gives the strong impression that 120,000 isn't even the totality of their full numbers, well who knows how much three-quarters of the VIII Legion is going to number. Either way, it sounds like Night is about to fall on Sotha.
If you wiggle it around a bit it also attracts space cats :p
