Kilofix Posted November 22, 2013 Share Posted November 22, 2013 I could convert or look on ebay, but assuming I wanted to buy: Chaos Terminator Chainfists x 10 (for my Apoc vs Titan squad) Chaos Marine Combi-Weapons (various for my HQs) .... where (what boxed set, bitz pack, etc. - Forgeworld included) would be the best place to get the above? Is only one Chaos Terminator Chainfist available in the Chaos Terminator box? Thanks. Link to comment https://bolterandchainsword.com/topic/283661-where-can-i-get-chaos-chainfists-and-combi-weapons/ Share on other sites More sharing options...
Major_Gilbear Posted November 22, 2013 Share Posted November 22, 2013 A bits seller is your best bet for the chainfists (Bitz Box, Bits and Kits, etc). Probably the same for the combi-weapons (which are all Terminator ones anyway, as there are no power-armoured Traitor ones that I know of). Failing that, you can make your own easily enough if you have some spares parts: - Chainfists = powerfists with a cut-down chain sword added - Combi-weapons = Chaos bolter or combi-bolters with parts from plasma pistols, hand flamers and so on added. Alternatively, I think the chaos vehicle sprues usually have a combi-weapon you can pinch, or you can use the new Sternguard combi-weapons with the Imperial icons and such trimmed off. If you only want to buy whole kits, Sternguard are a decent buy for special weapons and combi-weapons generally. Chaos Terminators have both of what you're looking for, although in more limited numbers. Not sure of any especially cost-effective way to get ten chainfists via any kit though. There are also two Forgeworld Terminator (Cataphractii and Tartaros) weapon-only kits that have a mixture of combi-weapons and chainfists in them, but you will likely need an expensive number of kits to fulfil the quantities you want. Link to comment https://bolterandchainsword.com/topic/283661-where-can-i-get-chaos-chainfists-and-combi-weapons/#findComment-3528478 Share on other sites More sharing options...
lhg033 Posted November 22, 2013 Share Posted November 22, 2013 the chaos terminator lord has a chainfist in as well plus combi's you could use a few loyalist chainfists and convert them with a bit of GS for the HQ combi's are these for terminator armour or power armour. the terminator combi's are pretty big on a PA marine - I was looking at doing this with one a while ago: slightly amended on a company master model Link to comment https://bolterandchainsword.com/topic/283661-where-can-i-get-chaos-chainfists-and-combi-weapons/#findComment-3528481 Share on other sites More sharing options...
Kilofix Posted November 22, 2013 Author Share Posted November 22, 2013 Oh hey thanks man. I actually wasn't aware of Bitz Box. They have what I'm looking for. Link to comment https://bolterandchainsword.com/topic/283661-where-can-i-get-chaos-chainfists-and-combi-weapons/#findComment-3528487 Share on other sites More sharing options...
Bungicats Posted November 23, 2013 Share Posted November 23, 2013 I'm not sure how good they are but CHapter House has what appears to be a decent combi-weapon that is not terminator based. http://chapterhousestudios.com/index.php?route=product/category&path=85_113 Link to comment https://bolterandchainsword.com/topic/283661-where-can-i-get-chaos-chainfists-and-combi-weapons/#findComment-3529000 Share on other sites More sharing options...
Quixus Posted November 23, 2013 Share Posted November 23, 2013 If you want to use third party combi-weapons, I recommend Anvil Industry's Lance Carbines. You get all the options (except Combi-Grav) and you can buy a set of five at a reduced price. Plus the castings (of other bits at least) are excellent just like the service of that company. Link to comment https://bolterandchainsword.com/topic/283661-where-can-i-get-chaos-chainfists-and-combi-weapons/#findComment-3529081 Share on other sites More sharing options...
