modular rhino bodies
Is it possible to make a rhino body completely modular by using magnets to be able to use it as a rhino, predator, razorback, vindicator, whirlwind? I have 3 rhinos and a razorback that I never use and I want to magnetize them to be as universal as possible. I cant remember the last time I used them as rhinos, I mainly use them as predators or whirlwinds, but I would like to make them modular.
https://bolterandchainsword.com/topic/283775-modular-rhino-bodies/
No need to magnetise anything to turn a Rhino into a Razorback, or vice-versa. Just leave the top hatches/plate loose and you can swap to your heart's content; same for a Predator without sponsons.
Also, if you take a Razorback's turret and cut the axle onto which the guns mount off the vertical piece, you can swap guns any time you like without the need to add magnets.
