Merellin Posted November 30, 2013 Share Posted November 30, 2013 Other then Grey Hunters, Long Fangs and Thunderwolf Cavalry, What units in the Space Wolf codex are actualy worth using? I'm unsure over the Claw units because of the BS and WS of 3.. I just want to know if any units other then the main 3 I listed are good, Because I want a bit more variation in my Space Wolf armylists..My normal lists are basically 1 Rune Priests, 1 9 man group of Grey Hunters in a rhino, 2 10 man groups of Grey Hunters in rhinos, 1 or 2 groups of Longfangs (If 1, 5 Missile Launchers, if 2, 3 missile launchers and 2 lascannons per group) and a group of 5 Thunderwolves.. Sometimes I use Njal instead of a Rune Priest.. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/ Share on other sites More sharing options...
Frater Cornelius Posted November 30, 2013 Share Posted November 30, 2013 Try running wolf rune priest with runic axe and divination (prescience) with 15 bloodclaws with free flamers and frost axe and a terminator stormshield frostaxe wolfguard pack leader. This will give you massive amount of attacks on the charge and reroll to hit, negating ws3 and you got sufficient ap2 attscks from priest and claws while your teminator can eat and win a challenge. Besides, ws3 is not that bad. You mostly hit on 4s anyway, just your opponent will hit on 3s. On that note we have skyclaws. Perfect way to deliver power fist and loads of krak grenades up the rear end of a tank. Other than that we have the good old Rifleman dread (dread with 2 TLAC). Decent firebase. Wolfguard drops are solid. Give them combi plasma and flamer/melta each, drop them to you opponent and let the hilarity ensue. For masses of WG, take Grimnar to buff them with preferred enemy and unlock them as troops. They are also your terminators. Take the hint Grimnar himself is a massive force multiplier. Check him out in higher point games. Land speeder are pretty cheap. Load them up with heavy flamer or multimelta then go fry something and annoy your opponent. Lone Wolf are HYLERIOUS. Huge fire magnet and very fluffy unit. Name them and then let them write their saga. One of mine once killed a Landraider Crusader with a BT command squad and the emperors inside. He killed them too and only lost his 2 wolves and 1 wound. But in the end, if you don't care about competitivenes, you can pretty much help yourself. Nothing is abysmal to the point of game breaking in friendly games. It's just the units you mentioned are extra good. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534479 Share on other sites More sharing options...
Leif-thunderstand Posted November 30, 2013 Share Posted November 30, 2013 Two groups of Longfangs is a good plan. 3 Teams of greyhunters are also an good choice. But if you want to make fast closecombat strikes to get the time you need for your longranged strikes, you could set blodclaws into your rhinos : reasoned to they berserk what seems actualy not that mighty on its own but helps a lot for this tactic. (BS WS 3 is not realy bad... Its just normal human style and for this job they dont need Bolters) On the other hand you could use your greyhunters also as guardians for your heavy fire suport. Â I am with Immersturm on that Your army should have your style. And any unit has its reason - we just need to know how to use em Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534515 Share on other sites More sharing options...
Bloody Legionnaire Posted November 30, 2013 Share Posted November 30, 2013 HEAVY BOLTER LONG FANGS ARE WONDERFUL! Just played a game with them, may have found my new favorite unit. 3 Heavy Bolter LFs with 2 Lascannon Long Fangs isn't a very expensive unit. Still gives you good long range/Anti-tank fire, yet gives you a lot of versatility. If anyone tries to charge in an assault your Pack of LFs, the HBs quickly smirk and let loose a hail storm of fire.. even at BS1 there's at least a few 6s you'll role. Get a prescience rune priest in there with them and see how many more of those misses you can make back! I know you asked for other than Long Fangs, but.. not many people run them with HBs cannot see why.Other than that, I do enjoy vindicators in certain lists. I want to play around with Pod'd shooty Dreadnoughts to see how they fare with the initial wave of Pods.2-3 Rune Priests have a great effect on the table top between buffs, denies, and shooting attacks. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534548 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted December 1, 2013 Share Posted December 1, 2013 ALL OF THEM!! Don't forget the classic, and always classy Lone Wolf with TDA, a Storm Shield, and a Chainfist!! End of Line Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534587 Share on other sites More sharing options...
Valerian Posted December 1, 2013 Share Posted December 1, 2013 Try running wolf priest with runic axe and divination (prescience) with 15 bloodclaws with free flamers and frost axe and a terminator stormshield frostaxe wolfguard pack leader. This will give you massive amount of attacks on the charge and reroll to hit, negating ws3 and you got sufficient ap2 attscks from priest and claws while your teminator can eat and win a challenge. I assume that you mean Rune Priest, vice Wolf Priest? Runic Weapon is always AP3, regardless of what "type" of weapon it is, so no AP2 with a Runic Axe. Also, Blood Claws can't take a Frost Axe, just a Power Axe. This isn't an expressly bad unit, but it isn't expressly good either. Lots of bodies to absorb wounds, but they have to footslog, so very poor Mobility for a dedicated Assault Force. They will spend much of the game running to find a unit to assault. They also have zero Firepower in an edition that is increasingly about Shooting over Close Combat. V ALL OF THEM!! Don't forget the classic, and always classy Lone Wolf with TDA, a Storm Shield, and a Chainfist!! End of Line Yep, that was going to be my recommendation too. I'd go with two of these and leave the 3rd Elite slot for a unit of Wolf Guard. You just really can't go wrong with a couple Lone Wolves on the table to Disrupt enemy units and adversary plans. V Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534636 Share on other sites More sharing options...
Denison512 Posted December 1, 2013 Share Posted December 1, 2013 i can recommend the SW version of the Contemptor dread... its a monster :D Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534646 Share on other sites More sharing options...
Bloody Legionnaire Posted December 1, 2013 Share Posted December 1, 2013 Any of you guys particularly like Landspeeders? Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534716 Share on other sites More sharing options...
Wolf Guard Dan Posted December 1, 2013 Share Posted December 1, 2013 I do.  They even made the top 5 (of this guys opinion): http://space-wolves-grey.blogspot.com/2010/12/top-5-space-wolves-units.html  And back then I agree. Now there is too much Str 7 fire on the field to be effective.  Unless you get really creative with deep striking. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534717 Share on other sites More sharing options...
Leif-thunderstand Posted December 1, 2013 Share Posted December 1, 2013 Landspeeders are very fine. Just take a look in your codex. They are quick, they are antigrav and you can add a lot of options. Hunting tanks with a TyphonMissleLauncher or Lascanons .... Hunting Xeno with Heavy Flamer ... Hunting Traytors with HBolters .... Hunting...Hunting.... Landspeeders can be used to any situation .... I Love them <3Landspeders<3 Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534751 Share on other sites More sharing options...
Frater Cornelius Posted December 1, 2013 Share Posted December 1, 2013 Try running wolf priest with runic axe and divination (prescience) with 15 bloodclaws with free flamers and frost axe and a terminator stormshield frostaxe wolfguard pack leader. This will give you massive amount of attacks on the charge and reroll to hit, negating ws3 and you got sufficient ap2 attscks from priest and claws while your teminator can eat and win a challenge. I assume that you mean Rune Priest, vice Wolf Priest? Runic Weapon is always AP3, regardless of what "type" of weapon it is, so no AP2 with a Runic Axe. Also, Blood Claws can't take a Frost Axe, just a Power Axe. This isn't an expressly bad unit, but it isn't expressly good either. Lots of bodies to absorb wounds, but they have to footslog, so very poor Mobility for a dedicated Assault Force. They will spend much of the game running to find a unit to assault. They also have zero Firepower in an edition that is increasingly about Shooting over Close Combat. V My bad, I meant rune priest. But I was under the impression that a power/force weapon has the stats of what is looks like, hence runic axe = power axe with force. They might have to footslog, but if you have 2 such squads on the field, well you may lose 4-5 but that's still more then enough hitting you. Add some ranged support a la LF (or like me, some Tau goodness) to that and happy chopping I'd say. Tried it a while back. The Imperial Fist gunline complained that there were too many bodies to chew through Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534844 Share on other sites More sharing options...
Leif-thunderstand Posted December 1, 2013 Share Posted December 1, 2013 Sorry - corecture: no lascanon but multimelters (dont know why i always think on that Lascanons) Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534854 Share on other sites More sharing options...
Rift Blade Posted December 1, 2013 Share Posted December 1, 2013 Land Speeders Tornadoes with MM & Hvy Fl. are finding there way back into my lists. Very effective against Tau & Eldar. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534867 Share on other sites More sharing options...
Leif-thunderstand Posted December 1, 2013 Share Posted December 1, 2013 And tyranids Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3534918 Share on other sites More sharing options...
Valerian Posted December 1, 2013 Share Posted December 1, 2013 Try running wolf priest with runic axe and divination (prescience) with 15 bloodclaws with free flamers and frost axe and a terminator stormshield frostaxe wolfguard pack leader. This will give you massive amount of attacks on the charge and reroll to hit, negating ws3 and you got sufficient ap2 attscks from priest and claws while your teminator can eat and win a challenge. I assume that you mean Rune Priest, vice Wolf Priest? Runic Weapon is always AP3, regardless of what "type" of weapon it is, so no AP2 with a Runic Axe. Also, Blood Claws can't take a Frost Axe, just a Power Axe. This isn't an expressly bad unit, but it isn't expressly good either. Lots of bodies to absorb wounds, but they have to footslog, so very poor Mobility for a dedicated Assault Force. They will spend much of the game running to find a unit to assault. They also have zero Firepower in an edition that is increasingly about Shooting over Close Combat. V My bad, I meant rune priest. But I was under the impression that a power/force weapon has the stats of what is looks like, hence runic axe = power axe with force. They might have to footslog, but if you have 2 such squads on the field, well you may lose 4-5 but that's still more then enough hitting you. Add some ranged support a la LF (or like me, some Tau goodness) to that and happy chopping I'd say. Tried it a while back. The Imperial Fist gunline complained that there were too many bodies to chew through Runic Weapons fit into the type of Unusual Force Weapon (page 60 of rulebook, right hand column), so they all are AP3 Melee weapons with the additional rules presented in its (codex) entry. V Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535089 Share on other sites More sharing options...
DanPesci Posted December 2, 2013 Share Posted December 2, 2013 i wont bother to repeat whats been said above (although..go lone wolves)  however, 15 fenrisian wolves can work wonders as a counter attack unit. Keep them in cover, wait for things to come to you, 45 WS4 S4 attacks on the charge. Fit the wolfkin saga in somewhere else in your option to make them I5 and watch the look of dismay on your opponents face as they rip through space marines due to sheer volume of attacks.  Not always the best option as they can get shot up easily, but definately very fun. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535474 Share on other sites More sharing options...
Merellin Posted December 2, 2013 Author Share Posted December 2, 2013 Whats a good way to equip a Lone Wolf? Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535553 Share on other sites More sharing options...
Warhead01 Posted December 2, 2013 Share Posted December 2, 2013  Any of you guys particularly like Landspeeders?  Very much! tornado and typhoon! They are expensive but I line to run 2 squadrons of 2 in smaller games and 3 of 2 in larger games unless I have the points for 3 of 3! So much fire power! But you have to learn how to use them and some will be destroyed regardless but 2 good shooting phases  could very well wrap up a game for you. I use them as a more flexible/mobile heavy support role. and I use long fangs. I also never deploy them and do not deepstrike them either. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535575 Share on other sites More sharing options...
DanPesci Posted December 2, 2013 Share Posted December 2, 2013 Whats a good way to equip a Lone Wolf? Â i usually run (as do a lot of people) Â TDA, chainfist, stormshield. with 2 dogs optional depending if i have the points spare. Â with 2 wounds, a 2+/3++ and FNP, (and two possible meatshields), these guys can soak up a hell of a lot of firepower with good dice. They chew through tanks, characters, and anything T5 with ease (bye bye bikes and plaguemarines). Â Â I sometimes also run them with plasma pistols and motw Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535595 Share on other sites More sharing options...
Merellin Posted December 2, 2013 Author Share Posted December 2, 2013  Whats a good way to equip a Lone Wolf?  i usually run (as do a lot of people)  TDA, chainfist, stormshield. with 2 dogs optional depending if i have the points spare.  with 2 wounds, a 2+/3++ and FNP, (and two possible meatshields), these guys can soak up a hell of a lot of firepower with good dice. They chew through tanks, characters, and anything T5 with ease (bye bye bikes and plaguemarines).   I sometimes also run them with plasma pistols and motw  That does look like a realy nice build, i'l try it out sometime. ^_^ And I had compleately missed that Lone Wolves had Eternal Warrior and Feel no Pain.. (Probably cus I only used them once and it never got hit.. xD)  Thanks for all the replies everyone! People here are realy friendly and helpful ^_^ Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535629 Share on other sites More sharing options...
Wolf Lord Wodan Posted December 2, 2013 Share Posted December 2, 2013 I want to run a lone wolf but I don't have the room. If I did I would probably go frost blade for the +1 S and a Storm shield for the 3++ Melta bomb (hell of a way to go for death or glory) and two wolves Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535633 Share on other sites More sharing options...
DanPesci Posted December 2, 2013 Share Posted December 2, 2013 the thing with the frost blade on a lone wolf, i prefer to trust in him surviving through 2+/3++/FNP, and then getting to hit with a beast of a weapon. In challenges, he's only I4, so against a lot of characters, hes going to be going last anyway. Â The CF also makes him deadly against vehicles and walkers, more so than just a sinlge meltabomb attack (combined with his reroll rules on walkers especially), and as such makes him a much more 'has to be dealt with before it rips through my tanks' unit. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535667 Share on other sites More sharing options...
Leif-thunderstand Posted December 2, 2013 Share Posted December 2, 2013 I am with danPesci on that. A CF is a much better choice than a Frostweapon. Especialy since the SpaceWolve got a TacticalCybotArmor ... Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535694 Share on other sites More sharing options...
Valerian Posted December 2, 2013 Share Posted December 2, 2013 There is about zero reason to use a Frost Weapon, ever. Always go with the PF/CF/TH option instead. I, personally, go with the Chain Fist for the same reasons above - nothing is safe (not even Land Raiders) from a Lone Wolf with a Chain Fist. Come get some! Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3535905 Share on other sites More sharing options...
Frater Cornelius Posted December 3, 2013 Share Posted December 3, 2013 Another good way is Power Armour, CCW, Stormshield, Mark of the Wulfen, 2 pet wolves. It's slightly cheaper than TDA Lone Wolf but get's more attacks against squisher targets with 1+d6 rending attacks. Link to comment https://bolterandchainsword.com/topic/283981-what-space-wolf-units-are-woth-using/#findComment-3536269 Share on other sites More sharing options...
