Pbenner Posted May 9, 2014 Share Posted May 9, 2014 I found that the ideal solution involves the hand from the DW Terminator Squad box that the DW Knight Captain uses for the flail. Cut it off flush on the top of the hand and use a 3/32" bit to drill down as deep as you can. Take a wire metal hanger and cut it off and sand it flat, glue it in the hole so that it is straight with the bottom. Attach with this. Paul Link to comment Share on other sites More sharing options...
johnyocum Posted May 9, 2014 Share Posted May 9, 2014 Thanks for the tips. Only 'bad' things are that I already have a termie with LCs and a back banner-pole AND currently can't afford to grab a box of Deathwing to get said flail hand. Though, when I get some cash, I'll pick that up and try it, and then pop the banner from the power-armor banner pole. Link to comment Share on other sites More sharing options...
