Calnus Posted December 18, 2013 Share Posted December 18, 2013 So, had a chance to play against a Fortune'd Seer Council the other day, and got lucky rolling Misfortune for my psychic power. Now, the question came up for which power takes precedence. Does Misfortune force the council to re-roll all failed saves, as normal, and prevent them from re-rolling any failures from Fortune? or does Fortune force the re-roll of all failures, using up the "single re-roll per die" rule before Misfortune activates? or do both occur simultaneously, forcing essentially a whole new roll for every save, regardless of whether it originally passed or failed? Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/ Share on other sites More sharing options...
Seahawk Posted December 18, 2013 Share Posted December 18, 2013 Option 3. Roll all saves twice is the way to play by the rules. Misfortune makes you reroll successes, and Fortune makes you reroll failures. You may agree with your opponent that both cancel out, but there is no basis in the rules for that. The reroll may matter, and only takes up a fraction of a second, so there's no real argument behind only rolling once other than "laziness". Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3549347 Share on other sites More sharing options...
Fibonacci Posted December 18, 2013 Share Posted December 18, 2013 Misfortune forces the unit to re-roll and successful armor saves. Fortune allows the re-roll of any failed armor saves. Notice that each affect different dice. For example if the unit attempts 6 armor saves and passes 2 of them, 4 dice would be re-rolled due to Fortune and 2 dice would be re-rolled due to Misfortune. Each die is only re-rolled once and all dice will be re-rolled. If you are feeling funny, a unit affected by both Fortune and Misfortune would roll for armor saves, pickup all the dice (both failed and successful rolls) and roll them again. It is normally easier to assume they cancel each other out and just roll once. Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3549353 Share on other sites More sharing options...
DarkGuard Posted December 19, 2013 Share Posted December 19, 2013 I'd still go by Seahawk's suggestion to re-roll them. The re-roll is not arbitrary, and luck does strange things. You may find yourself actually cheating your opponent, or even yourself, if you don't make the re-roll. Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3549571 Share on other sites More sharing options...
Grey Mage Posted December 19, 2013 Share Posted December 19, 2013 Statistically it wont change anything, but statistics.... well, if we all went by that we would have little cause to put bases to table tops. Still, I usually ask for the gentlemans agreement of 'first roll, no rerolls' Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3549680 Share on other sites More sharing options...
hallodx Posted December 19, 2013 Share Posted December 19, 2013 I think it's simple. You reroll all, since there are only passed or failed, and both kind should be rerolled, just reroll all. And yeah, statistically it's the same. Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3549686 Share on other sites More sharing options...
Morollan Posted December 19, 2013 Share Posted December 19, 2013 We had a situation last night where one player was rolling a shooting attack and thought his model was BS5. He'd rolled to hit and wound before he remembered that it was actually only BS3. So we agreed to just start again and reroll to hit. Despite having 2 less BS than the first time he actually hit and wounded with more shots. Statistics rarely resemble reality when dealing with a sample size this small. Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3549790 Share on other sites More sharing options...
Dam13n Posted December 19, 2013 Share Posted December 19, 2013 Given that you would roll all your dice, then have to re-roll all of them. The reasonable solution is to agree with you opponent before rolling the first time if you will bother re-rolling at all. The RAW is that every die must be re-rolled However, not re-rolling at all is quicker and has the same statistical spread. The Warhammer FAQ (although not 100% relevant) does have something to say on the matter: Q: If a model is granted a re-roll To Hit from a special rule such asHatred but the model they are attacking has a special rule, magicitem etc. that forces successful To Hit rolls to be re-rolled, how is thisdealt with? (p7)A: They cancel each other out and no re-rolls are made for aslong as both special rules are in effect. So, that should still be the answer were the question posed from a 40k perspective. Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3550094 Share on other sites More sharing options...
Morollan Posted December 20, 2013 Share Posted December 20, 2013 The 5e FAQ said much the same. Q: If a unit has a special rule that lets it re-roll failed saves and is being affected by an enemy special rule that makes them re-roll successful saves how is thisresolved? (p25)A: Whilst you should technically roll all the dice and then re-roll them, just roll the saves once and apply the results to save time. Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3550534 Share on other sites More sharing options...
Spinsanity Posted December 20, 2013 Share Posted December 20, 2013 Note that this should be agreed to before any dice are rolled... i've seen players roll their dice (attacks, saves, whatever) and depending on their original roll (good or bad) argue that they should or shouldn't reroll everything afterwards... (Sometimes changing stance midgame, of course) Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3550666 Share on other sites More sharing options...
Seahawk Posted December 20, 2013 Share Posted December 20, 2013 Consistency is the most important thing here. I for one will always take the reroll, because that's how I . Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3550737 Share on other sites More sharing options...
Grey Mage Posted December 20, 2013 Share Posted December 20, 2013 Will.... not... click.... link..... Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3550752 Share on other sites More sharing options...
hallodx Posted December 21, 2013 Share Posted December 21, 2013 Consistency is the most important thing here. I for one will always take the reroll, because that's how I .Now reroll. (Click |<< Link to comment https://bolterandchainsword.com/topic/284684-misfortune-vs-fortune/#findComment-3551097 Share on other sites More sharing options...
