Roma Posted December 24, 2013 Share Posted December 24, 2013 DO you need LOS for burning brand? Cheers? Link to comment https://bolterandchainsword.com/topic/284894-burning-brand-and-los/ Share on other sites More sharing options...
MikeyB83 Posted December 25, 2013 Share Posted December 25, 2013 afaik you need to be able to see at least one model with this template weapon to be able to fire. the rules state you must cover as many models as possible but this a slight loop hole. if you can only see one model how do you place the template is the question i'm seeing. i'd say its down to interpretation at the time, how they can fire (no right angles if its say 3" etc) and sportsmanship. this might just be my interpretation of what has been asked here, if you see what i mean. but generally, you will need to see at least one model to be able to fire, template or not. hope this helps. Link to comment https://bolterandchainsword.com/topic/284894-burning-brand-and-los/#findComment-3553594 Share on other sites More sharing options...
hallodx Posted December 25, 2013 Share Posted December 25, 2013 My interpretation is, you can cover as many as you want, but only hit those you can see, which if it was one model here, you can only have one Hit. Link to comment https://bolterandchainsword.com/topic/284894-burning-brand-and-los/#findComment-3553626 Share on other sites More sharing options...
Dam13n Posted December 25, 2013 Share Posted December 25, 2013 Not exactly true. You must be able to see at least one model in the target unit in order to declare a shooting attack against them (unless firing an indirect barrage). You place the template to score as many hits as possible. That is the number of hits scored (even if models covered by the template are out of sight). Wounds can only be allocated to models that the firer has line of sight to. Link to comment https://bolterandchainsword.com/topic/284894-burning-brand-and-los/#findComment-3553750 Share on other sites More sharing options...
hallodx Posted December 25, 2013 Share Posted December 25, 2013 Not exactly true. You must be able to see at least one model in the target unit in order to declare a shooting attack against them (unless firing an indirect barrage). You place the template to score as many hits as possible. That is the number of hits scored (even if models covered by the template are out of sight). Wounds can only be allocated to models that the firer has line of sight to. So it's not "Hit" but "allocate to" those models in LoS? Got it! Link to comment https://bolterandchainsword.com/topic/284894-burning-brand-and-los/#findComment-3553752 Share on other sites More sharing options...
