Changing Weapons In The Same Assault
The Rose Princes
So I'm gonna run a secondary Lord with Frost Axe and Power Weapon.... so if I run into mixed unit (such as termagaunts with an attached prime), I can use the axe on the challenge since he's faster than me anyway, but still get the extra attack for 2 close combat weapons.
Afterwards, because there will still be plenty of termagaunts left, can I then switch to the Power Weapon because then I'll be faster than them for the next rounds of combat?  In Fantasy there is a specific rule preventing this (and a special ruke orcs have for allowing it), but I don't seem to be able to find any mention of it in 40k.
Is switching weapons in the same Assault, not the same Assault Phase, allowed?
In later game turns you can, BUT I don't think you're allowed to split it up within a phase (?). Often this doesn't matter anyway because depending on the unit you are facing, one weapon or the other is going to be clearly superior.
Also, unfortunately power fist plus wolf claw is mostly better than dual frost weapons, power weapons, or frost plus power weapon. Similar price, still get extra attack and flexibility, but they're more hurty weapons. Frost weapons look cooler though. And I imagine frost weapons will get buffed somehow when our codex is updated, possibly some time mid to late 2014.
I was going this specific route because powerfists, wolf claws & thunder hammers are Specialty Weapons while regular power and frost weapons are not.... this way I get the +1 attack with both weapons; going with the Saga of the Warrior Born on this one so trying to maximize attacks, and saving 10 points by just using power weapon and not frost blade to be economical.
Oh, I see what you mean; I had to reread Specialty Weapon.  I had assumed it meant the same Specialty Weapon, not ANY Specialty Weapon.
Well, that puts a different spin on everything.  Back to the speadsheet!
Thanks everyone.
Logan is the only exception to this in allowing you to choose/divide your attacks between the two characteristics of the ax of morkai.
So, there is actually a rumour that the rules for pistols will change with the release of the next 'edition', this year some time. Its just a rumour of course. But apparently pistols will give the option of making the +1 attack using the statistics of the pistol. So a plasma pidtol would be str 7 ap 2, at initiative, i guess. Making frost weapons an interesting option. IF that comes to pass.
Like the new Cypher dataslate.
