Matching airbrush paints to citadel?
Wulfebane
With my new airbrush, I'm looking to get a few paints that match some of Citadel's newer shades. My google-fu is fairly weak, so I'm having trouble finding a conversion chart for a select few of the new colors, specifically Eshin Grey and Zandri Dust.
I've mixed some small batches, but with the cost per bottle, its unrealistic to make larger batches. I'd much rather find out if vallejo model air or badger minitaire (or equivalent) have a comparable color (and/or if anyone has a FULL conversion chart including all of the new paint colors).
You can easily thin the citadel colors to use them in your airbrush, so there is no real need for alternatives.
But if you thin them i would recommend Tamiya X20a Thinner, which is based on alcohol.
It works fine with every color brand i use like Armypainter, VMC, VMA, Citadel.
Even the Base colors of the citadel range work if you thin them and use a 0,4 mm nozzle.
