ShasVa Posted December 29, 2013 Share Posted December 29, 2013 Just wanted to see what you all thought of these ideas, and how viable they could be in the fluff. Volkite Ammunition: An attempt to regain arcane Imperial technology from the time of the Horus Heresy and before. The uranium core is replaced with a seal containing two highly-volatile thermal chemicals, which are separated until penetration of the target has been made. Once this is done, the seal breaks, causing the two chemicals to mix, which results in a devastating release of thermal energy. The end result is that the target will burn from the inside-out, and soon after, explode. Railbolt Ammunition: An Imperial attempt to reverse-engineer and miniaturize the railgun weapons used by the Tau. The rounds have a slightly smaller caliber than normal ammunition, and the standard charge is replaced with a tiny capacitor. Once fired, this capacitor releases electromagnetic energy on a delayed fuse, causing the round to fire out at speeds above supersonic. Link to comment Share on other sites More sharing options...
Quixus Posted December 29, 2013 Share Posted December 29, 2013 @Volkite Ammunition: Isn't that more ore less the same thing that the standard bolter shell does? It penetrates and explodes. Volkite weapons from 30k are some kind of energy beam weapon. @Railbolt: "above supersonic" does not make much sense. Supersonic already means above the speed of sound, which isn't that fast (~3.4*102 m/s) anyways. If you want so say it is really fast, make it close to the speed of light (~3*108 m/s). Link to comment Share on other sites More sharing options...
Kol Saresk Posted December 29, 2013 Share Posted December 29, 2013 @Volkite Ammunition: Isn't that more ore less the same thing that the standard bolter shell does? It penetrates and explodes. Volkite weapons from 30k are some kind of energy beam weapon. @Railbolt: "above supersonic" does not make much sense. Supersonic already means above the speed of sound, which isn't that fast (~3.4*102 m/s) anyways. If you want so say it is really fast, make it close to the speed of light (~3*108 m/s). I don't think railguns accelerate projectiles to quite that speed. However, there is a term called "hypersonic", which means "highly supersonic". It is used in reference to speeds that are normally Mach 5 and above and is used in relation to railguns. So instead of "speeds above supersonic", maybe something like "accelerates to hypersonic speeds of above Mach 5." Volkite ammunition is a good idea except that Volkite weapons are energy based IIRC. So instead it could be switched to "Volkite power source". Link to comment Share on other sites More sharing options...
