L30n1d4s Posted January 2, 2014 Share Posted January 2, 2014 Here is the scenario: you take a SM Chapter Master with the Teeth of Terra Relic and a PF, giving him 4A base + 1A (for two specialist weapons) +1A on th charge for 6 attacks on the charge. Now, part of the Teeth of Terra Special Rules is that it gives its user Rampage (i.e. +D3 attacks if he is outnumbered)... obvioulsy this would apply if he is using the Teeth of Terra (giving him between 7-9 attacks on the charge), but does it also apply if he uses his PF instead of the Teeth of Terra? The Teeth of Terra rules simply say: Specialist Weapon, Rampage, Strikedown.... I am not certain if the Rampage part of that applies no matter what weapon the Chapter Master is using or only if he is using the giant Relic Chainsword. Any thoughts/insight? Link to comment Share on other sites More sharing options...
Demus Ragnok Posted January 2, 2014 Share Posted January 2, 2014 Well, it seems that the rule applies to the weapon and not he model. Therefore the rule would not be in action if the weapon isn't being used. Just my 2 cents. Link to comment Share on other sites More sharing options...
3DJutsu Posted January 2, 2014 Share Posted January 2, 2014 Exactly. Similar situation would be a Librarian with a Force Axe and Power Sword. You get the extra attack but the special rules from only one weapon. Otherwise the aforementioned Librarian setup would Effectively have a Force Sword and a Force Axe. Another example would be Force Sword / Thunderhammer or Power Fist. Though 'Force Fists' or 'Force Hammers' sound pretty sweet. Admit it, you know you want it. Link to comment Share on other sites More sharing options...
Demus Ragnok Posted January 2, 2014 Share Posted January 2, 2014 Exactly. Similar situation would be a Librarian with a Force Axe and Power Sword. You get the extra attack but the special rules from only one weapon. Otherwise the aforementioned Librarian setup would Effectively have a Force Sword and a Force Axe. Another example would be Force Sword / Thunderhammer or Power Fist. Though 'Force Fists' or 'Force Hammers' sound pretty sweet. Admit it, you know you want it. Off Topic but the Iron Hands Supplement has one. Link to comment Share on other sites More sharing options...
3DJutsu Posted January 2, 2014 Share Posted January 2, 2014 Forgot to include a reference. Pg51 of the DVRB under 'More than one weapon'. Exactly. Similar situation would be a Librarian with a Force Axe and Power Sword. You get the extra attack but the special rules from only one weapon.Otherwise the aforementioned Librarian setup would Effectively have a Force Sword and a Force Axe.Another example would be Force Sword / Thunderhammer or Power Fist. Though 'Force Fists' or 'Force Hammers' sound pretty sweet. Admit it, you know you want it. Off Topic but the Iron Hands Supplement has one. I'm... gonna have to look into that. O_O Link to comment Share on other sites More sharing options...
