hot shot las gun!
MomentoMori
I've been running henchmen squads of 6x warriors w/ carapace, HSLG and 2x Jokero loaded into a rhino.  Two games played since my return and I can say that 30" HSLGs are Gold. Rapid firing at 15" is just murderous against MEQ squads.  Though don't always count on it. I also got Rending on one roll and a 5++ as well.
  • I use storm bolters and run two Jokeros which usually gives them both rending and an additional 12" of range.    I was running two acolytes with plasma guns (which is good if you plan to assault with them) but have recently changed to three servitors with plasma cannon as they were cheeper in the squad with an inquisitor to sit back and shoot.
Plasma cannon servitors > Acolyte plasma guns. You do pay a bit more, but blast AP2 is just hell on infantry of all stripes. Combined with 'Perfect Timing' and/or 'Prescience', you can obliterate enemy infantry at will. I've been running that combo since the 6th edition powers came out, it's brutal :)
Using either combination of C:GK or C:I as primary, with Dual FoC, you can get a total of 7 PML1 Inquisitor + 3 Plasma Cannon Servitor units.
Each costs you 115 points, so 805 total.
You like mass Longfangs and Missile Launchers?  These 7 units are right up your ally!
Only downside is you can't hit fliers or overwatch with them!
And you can add 4 point meatshields to each unit as well!
Edit: So you don't play 2,000 points, or Dual FoC isn't allowed.
You can get 5 of these units.
Primary - Codex: Grey Knights;
HQ: Inquisitor, PML1 (55)
Elite: Servitor x3, Plasma Cannon x3, Warrior Accolyte x2 (38)
Inqusitorial Detachment;
Total: 465
For 15 'twin-linked' Plasma Cannons!
If you're playing 1,850 points, that's nearly 1,400 left for Troops/Scoring units!
Hotshots although nice on the models are for the points you pay just bad, storm bolters are better in every situation even against power Armour due to strength range and assault vs rapid fire if you are interesting here's the maths worked out in detail -http://bestoverall.blogspot.co.uk/2011/04/maths-request-hotshot-versus.html
