Legion chosen, modelling advice required...
KJB
Ok, being the king of indecision that I am, this has been doing my head in for about 6 months and has cost me a small fortune so far, but I've finally decided on a legion to choose....
As always, I'm inevitably drawn back to my first 40k army, the sons of Vulkan, the XVIIIth, the great and glorious Salamanders
Now, what I need from my brilliant (and annoyingly decisive) brothers (that's you) is a few final pieces of advice before I get paid on Friday and place my first order of the year to Forge World...
So, on with the questions...
1. Armour marks.
So, the Salamanders are technically advanced, which suggests Mk IV armour, however, they specialize in shortrange fire fights and enjoy burning things, which always makes me think Mk III - What do you guys reckon? (The new Mk III command squad sure looks purdy...)
2. Armour marks (part 2)
When you build your legion forces, do you try and keep the full force in the same mark of armour? Or just keep squads in the same mark? Or just mix and match bits up for the fun of it?
3. Inferno pistols
The only Inferno pistols I can find are the plastic Blood Angel ones, which lets face it, don't scream 30k, or even look good - What do you think of using the Hand Flamer from the MkIII weapons set?
That's all for now, undoubtedly I'll be back with more random questions - Cheers guys!!
I would of said Mark IV tbh. Like you said, they're technically advanced and that would of been the the top mark at the time. Jus sayin
Mark III better suits their temperament. That, and Mark III has the oldest look to it, aesthetically. Adding embellishments would make it very Salamandery.
1. Mostly Mk III with some Mk V to show post-Istvaan scavenging. Perhaps use Mk IV for veterans?
2. I like to keep the individual squads in the same marks, that's because I like a uniform look, and only characters are given mixed armour. But each Salamander crafts his own armour and after Istvaan they will have been forced to use any material available, so mixing marks would fit your army.
3. Not sure. Try removing the muzzles from the Mk III hand flamers and replace them with those from the pre heresy meltas.
My Iron Hands' core is MkII, but I will embellish the army with some smatterings of MkIII.
I see it that MkII is standard issue, and would have eventually be replaced by MkIV. MkIII is a special upgrade to MkII that certain units may require for their hazardous roles.
Tacticals = MkII
Breachers = MkIII
Heavy weapons = ...depends on the unit. My Missile Launcher team are MkII, Lascannons will be MkIII.
    If I do a Volkite Caliver squad, it'll also be MkIII.
My Master of Signal will be in Artificer MkIII.
I'd suggest the Iron Hands squads... yeah, you'll need to file off some of the excess stuff, but their Mk. III armor is heavily personalized, there's a lot of bionic bits to be used as well, and let's face it... a Veteran Astartes is going to lose a limb or two along the way.
