Cpt Lazarus Posted January 20, 2014 Share Posted January 20, 2014 Painting up my new stormtalon and i'm having issue's with the canopy. any tricks for painting the support braces without making an unholy mess around it? Link to comment https://bolterandchainsword.com/topic/285852-canopies/ Share on other sites More sharing options...
GodEmperorOfMankind Posted January 20, 2014 Share Posted January 20, 2014 Use masking tape on the clear sections? Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3574252 Share on other sites More sharing options...
Cpt Lazarus Posted January 20, 2014 Author Share Posted January 20, 2014 tried it, didn't stick too well and the paitn bled under. Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3574265 Share on other sites More sharing options...
Gurth Posted January 20, 2014 Share Posted January 20, 2014 Mask the whole cockpit with proper masking tape — not any random tape like what you’d use to stick two bits of paper together — and then use a hobby knife with a sharp (new) blade to cut along the frame (use only very light pressure on the knife to avoid cutting into the plastic). Next, make sure the edges of the masking tape are stuck to the part by burnishing them a bit with your finger, your nail, the rear end of a paintbrush, or similar. Then paint the part, but try to always move your brush away from the edges of the tape — not toward them. Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3574333 Share on other sites More sharing options...
Cpt Lazarus Posted January 20, 2014 Author Share Posted January 20, 2014 thanks GURTH. will try that out Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3574568 Share on other sites More sharing options...
twopounder Posted January 20, 2014 Share Posted January 20, 2014 Use blue painters tape. This is a bit more expensive, but it's designed specifically for taping off painting areas and doesn't leave behind residue. Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3574611 Share on other sites More sharing options...
Fibonacci Posted January 20, 2014 Share Posted January 20, 2014 Since we are talking about canopies, beware of using superglue with clear plastic. It gives off an invisable vapor that will fog the plastic when it dries. Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3574640 Share on other sites More sharing options...
Cpt Lazarus Posted January 20, 2014 Author Share Posted January 20, 2014 I Use GF9's hobby glue. will that fog the canopy? Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3574654 Share on other sites More sharing options...
Lancer Posted January 20, 2014 Share Posted January 20, 2014 You can dip your canopies in future floor polish (made by SC Johnson) to avoid the fogging created by superglue. Added bonus of giving the canopies a crystal clear appearance to boot. Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3574710 Share on other sites More sharing options...
Gurth Posted January 21, 2014 Share Posted January 21, 2014 Both model cement and superglue can cause “crazing” — that is, the transparent parts turning white. The best way to avoid it is to use a different type of glue altogether: white (PVA/woodworking) glue works fine, for example, or if you expect to glue transparent parts a lot you could buy a bottle of modelling glue specially formulated for clear parts, such as Humbrol Clearfix (there are other brands — I’m just listing the one I can remember off the top of my head). Link to comment https://bolterandchainsword.com/topic/285852-canopies/#findComment-3575015 Share on other sites More sharing options...
