Butters Posted January 20, 2014 Share Posted January 20, 2014 In the new Tyrannic War Veterans data slate that came out the cost of Cassius is significantly less. Does this override the original SM: Codex? Link to comment Share on other sites More sharing options...
stinkenheim Posted January 20, 2014 Share Posted January 20, 2014 I would say no, mostly because iirc the data skate requires you to purchase a specific set of units and they wouldn't benefit from the ultramarine combat tactics. Seems like a fair reason to discount his points. Link to comment Share on other sites More sharing options...
Dam13n Posted January 20, 2014 Share Posted January 20, 2014 The cost of any unit is as listed in it's relevant slot. So Cassius in codex SM costs X pts And Cassius in the Data-slate costs Y pts You use the points cost of the version you are using. Simple as. Link to comment Share on other sites More sharing options...
Butters Posted January 21, 2014 Author Share Posted January 21, 2014 So its basically a perk for taking that selection of units. You get X stats as well as a decrees in points. Link to comment Share on other sites More sharing options...
Seahawk Posted January 21, 2014 Share Posted January 21, 2014 In the new Tyrannic War Veterans data slate that came out the cost of Cassius is significantly less. Does this override the original SM: Codex? No, because they are exactly the same points cost. There is no discount. Link to comment Share on other sites More sharing options...
Butters Posted January 21, 2014 Author Share Posted January 21, 2014 My fault I was looking something wrong. He is the same amount. For some reason I was thinking 185 pts for Cassius! Link to comment Share on other sites More sharing options...
