Ch@oZ Posted January 22, 2014 Share Posted January 22, 2014 Hi everybody. I'm currently scratchbuilding two things based on two different papercraft templates and seeing that there are sizing discrepancies between them I need Your help. So here are my questions: 1. Is the clear canopy on the storm talon and the dark talon/nephilim jetfighter the same size? I assume they are, but the templates say otherwise (~20% difference seems suspicious). Pictured below- stormtalon top, nephilim bottom. Woot? 2. Can anyone in possession of a dark talon/nephilim verify that the following pictures show a model at the right size, please? (just in case) 15 cm= 6 inches I'd be much obliged for any assistance in this matter. Or any pictures of the original models (or just parts thereof), especially the canopy (canopies?) next to a ruler/any measuring device. Link to comment Share on other sites More sharing options...
Grotsmasha Posted January 22, 2014 Share Posted January 22, 2014 Storm Talon http://www.games-workshop.com/MEDIA_CustomProductCatalog/m2390199a_99120101094_StormTalon01_445x319.jpg Dark Talon http://www.games-workshop.com/MEDIA_CustomProductCatalog/m2860299a_99120101095_DarkTalon01_873x627.jpg The pictures certainly *appear* to be the same canopy, but it's possible that the variance comes from the paper templates being slightly a different scale? Cheers, Jono Link to comment Share on other sites More sharing options...
Ch@oZ Posted January 23, 2014 Author Share Posted January 23, 2014 I've since discovered where the discrepancy stems from- the fact, that the little sunshade the dark talon canopy has on the top has a 2-2,5mm thickness, but the paper template assumes, that the canopy goes straight down, directly from the rear wall of the cockpit. Essentially, they've made the dark canopy "oversize", assuming your building materials have no thickness whatsoever. Link to comment Share on other sites More sharing options...
The_Chaplain Posted January 23, 2014 Share Posted January 23, 2014 Can anyone in possession of a dark talon/nephilim verify that the following pictures show a model at the right size, please? Yep, looks right to me. Absolutely phenomenal that you are building that from scratch using templates. The canopies between the two models should be exactly the same. Link to comment Share on other sites More sharing options...
