GrandMagnus Posted January 26, 2014 Share Posted January 26, 2014 Hey brothers, Im planning to eventually add some deathwatch to my Ultramarines army, but there is no way in :cuss that Im going to pay 23 € for a few pauldrons from GW. What do you suggest I can do about the Deathwatch pauldrons? Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/ Share on other sites More sharing options...
Cornelias Posted January 26, 2014 Share Posted January 26, 2014 bitz order the plastic ones :) Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3579054 Share on other sites More sharing options...
GrandMagnus Posted January 27, 2014 Author Share Posted January 27, 2014 bitz order the plastic ones From where? I suppose I could try eBay, but are there any other stores? I usually use Bitzbox, but they are all out. Thank you for the reply though ;) Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3579437 Share on other sites More sharing options...
Lysere Posted January 27, 2014 Share Posted January 27, 2014 Buy command squads and commander boxes whenever you might want them. They should each come with about two should pads each for deathwatch. I might be wrong on the commander box but I know the command squad does. The advantage of the deathwatch kit is it gives you the unique bolters with fire selectors that you can't normally get in any kit. Plus its enough for ten different models to become deathwatch marines. (Only the left shoulder gets the deathwatch should pad after all) Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3579459 Share on other sites More sharing options...
GrandMagnus Posted January 27, 2014 Author Share Posted January 27, 2014 Yeah, but for 23 € its not worth it. Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3579689 Share on other sites More sharing options...
Hemal Posted January 27, 2014 Share Posted January 27, 2014 Bitz box and avrious other bitz stores do stock these parts. Otherwise plump for the Deathwatch conversion sprue if GW still sell it - also has teh veteran's bolters.. Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3579947 Share on other sites More sharing options...
Cornelias Posted January 27, 2014 Share Posted January 27, 2014 bits and kits, let the dice decide and valhalla gaming on ebay etc. should see you ok. Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3580002 Share on other sites More sharing options...
Disruptor_fe404 Posted January 27, 2014 Share Posted January 27, 2014 Commander box has one, Command Squad box has two. Neither has anywhere near the detail of the metal/Finecast ones that come with the bolters. Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3580097 Share on other sites More sharing options...
Slave to Darkness Posted January 27, 2014 Share Posted January 27, 2014 i think i have some of the plastic ones, might have five im not sure. want me to have a look? Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3580127 Share on other sites More sharing options...
Kaedes Nex Posted January 28, 2014 Share Posted January 28, 2014 Yeah, but for 23 € its not worth it. Actually, it is worth it if you use all the bits. 30 bits for $25 is under $1 a bit. Bits go for $1 minimum on eBay. Sometimes $0.50, but usually $1 minimum for a single bit. If you buy a whole sprue with multiple bits on it then it will be cheaper, but that's about the average price. If you don't use the heads, it's still close to $1 per bit. If you compare getting the plastic Deathwatch shoulders by only buying boxes or from eBay/bits sites, it costs more and you can't get the bolters. Not trying to convince you to buy GW's pack, just giving some perspective. GW's little upgrade packs tend to be worth it. Like their old kit of 5 meltas for $10. Very worth it back when melta guns cost $10 each on eBay and only came on per box. Also I've paid up to $5 for a single helmet before. The Venerable Dreadnought helms, Forge World bits, and the rare Black Templar Mk VII crusader head with no vent grills. So dealing in bits can often be "not worth it" as people sell individual pieces for much higher cost to meet the demand and make profit. Link to comment https://bolterandchainsword.com/topic/286097-deathwatch/#findComment-3581149 Share on other sites More sharing options...
