Shadespyre Posted January 26, 2014 Share Posted January 26, 2014 The old Rogue Trader attack bike has the side car connected at just one point, and I'm finding they have often bent or broken at that joint, so I'm thinking they would be safer on bases to take the strain off the join. So does anyone currently base their attack bikes and if so on what? Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/ Share on other sites More sharing options...
Xenith Posted January 26, 2014 Share Posted January 26, 2014 Dreadnought base is probably the best and easiest! Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3579207 Share on other sites More sharing options...
Paulochromis Posted January 26, 2014 Share Posted January 26, 2014 but one of the ways to minimise the footprint of the double MMAB squad is to have them face each other, and that is not possible once you base them. Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3579224 Share on other sites More sharing options...
Shadespyre Posted January 27, 2014 Author Share Posted January 27, 2014 I really must BUY some bases so I can judge these things more easily, blu-tacked one together and it fits exactly on a 50mm square so I think 60mm round will be perfect, thanks. .... do people really do that? I'm glad I don't play in that sort of environment! Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3579253 Share on other sites More sharing options...
JamesI Posted January 27, 2014 Share Posted January 27, 2014 My attack bikes are on dreadnought bases. Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3579256 Share on other sites More sharing options...
Seleucus Posted January 27, 2014 Share Posted January 27, 2014 I've notced a number of manufacturers have started providing wider bike bases e.g. Dragonforge: http://dragonforge.com/Painting%20service/for%20sale/base_sets/sci-fi/ancient%20ruins.htm I have not tried them, or measured out attack bikes (current or RT), so don't know if they fit. Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3579274 Share on other sites More sharing options...
JeffTibbetts Posted January 27, 2014 Share Posted January 27, 2014 I put a standard circle base under the tire of my sidecar. It doesn't take the strain off the joint, but it makes me giggle every time I look at it. It's like a little bubble of baseness under the wheels. Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3579299 Share on other sites More sharing options...
Hemal Posted January 27, 2014 Share Posted January 27, 2014 Why not put them on a roughly traingular piece of plasticard or wood? There's an idea - an attack bike base - might try and mock one up tonight... Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3579547 Share on other sites More sharing options...
Shadespyre Posted January 27, 2014 Author Share Posted January 27, 2014 Hmmm, I quite like the wider bike bases from Dragonforge, they would tie in nicely with the normal bike bases. I wonder if I can find any in plain plastic / resin / mdf. A triangle, obviously with rounded corners for the WH40k aesthetic, would work pretty well too. As for the round base under the wheel, I'd considered that, only with the bike base across wise to support the rear wheel and sidecar wheel, and a single round base under the front wheel! Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3579994 Share on other sites More sharing options...
Aspecti Posted January 27, 2014 Share Posted January 27, 2014 I use 1.5 bike bases for my attack bikes to make an L shaped base :) Works fine and the base isn't too big for anyone to whine about. Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3580135 Share on other sites More sharing options...
elmo Posted January 27, 2014 Share Posted January 27, 2014 I use the standard 60mm base. It just fits. http://th07.deviantart.net/fs71/200H/i/2012/350/8/0/attack_bike__1st_squad__2nd_company__ravenwing_by_elmo9141-d5o7v4q.jpg Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3580149 Share on other sites More sharing options...
Shadespyre Posted January 27, 2014 Author Share Posted January 27, 2014 Very nice! The old version is rather smaller I think so will fit even better. (Love your magnetised tanks tutorial btw!) Link to comment https://bolterandchainsword.com/topic/286104-bases-for-attack-bikes/#findComment-3580181 Share on other sites More sharing options...
