Dark Haven Posted January 27, 2014 Share Posted January 27, 2014 I apologize if these have been asked before, I am new to the DA. Page 64 – Power Field Generator Add “If the bearer is embarked upon a Transport vehicle, the powerfield’s effects only apply to models embarked upon that vehicle”. Q: The Standard of Devastation states that ‘all friendly Codex: Dark Angels units within 6” of the standard treat their boltguns as Salvo 2/4 weapons’. Which boltguns does this apply to? (p66) A: This applies to the standard boltgun (24”range, S4, AP5, Rapid Fire), twin-linked boltguns on bikes, the bolter component of combi-weapons, and hurricane bolters. My questions are as follows: 1. If only the embarked squad is affected by the powerfield, does that mean that the vehicle they are in doesn't get the 4++? 2. If I put the command squad with a Sacred Standard (Dev, Fort or Ret) in a dedicated transport, can they still effect my DA units within 6" or 12" respectively? Would I measure from the hull of the vehicle or would the squad have to disembark to give the benefit? 3. A Veteran that is upgraded to an Apothecary cannot take any further upgrades? I believe that he cannot, am I right? Link to comment Share on other sites More sharing options...
[TA]Typher Posted January 27, 2014 Share Posted January 27, 2014 1: Correct. The April FAQ gutted the PFG. Only the unit inside gets the 4++. Horrible FAQ. 2: Yes. The banner does extend from the vehicles hull. Thankfully the April FAQ didn't kill this too. 3: Correct. Unlike C:SM Apoths ours only have a CCW. I don't know why... it makes no sense, but what can you do? Link to comment Share on other sites More sharing options...
andrewclark85 Posted January 30, 2014 Share Posted January 30, 2014 It says that any model in the squad can swap his bolt pistol and/or cc for... I believe the apothecary to be part of that any model and give him a bolter Link to comment Share on other sites More sharing options...
MadDoc Posted January 31, 2014 Share Posted January 31, 2014 @andrewclark85 - I'm not sure what Codex you're looking at but for Command Squads mine says "Any Veteran may replace his chainsword and/or bolt pistol with a:" not "Any model", and nothing in any official FAQ I've seen has altered that wording. Link to comment Share on other sites More sharing options...
Master Sheol Posted January 31, 2014 Share Posted January 31, 2014 In addiction C:SM Apothecary swap His Bolt pistol For narthecium too... It's Stated in Command Squad entry... And in vanilla comma e squads apothecary cannot upgrade His wargear too... Link to comment Share on other sites More sharing options...
Master Sheol Posted January 31, 2014 Share Posted January 31, 2014 And about the PFG nerf... First it's a horrible errata that Goes against the BRB where is stated that area effects spread from the hull of a transport... Second the FAQ strangely appeared when the Tau codex came out and if you notice tau have problema to deal with armour 14 so i think GW nerfed PFG to give tau less problems to be the dominating codex in Order to sell more gundams... :P Link to comment Share on other sites More sharing options...
Pyro X Posted January 31, 2014 Share Posted January 31, 2014 If ours got nerfed I really hope that the one Orks use does also. Link to comment Share on other sites More sharing options...
shabbadoo Posted January 31, 2014 Share Posted January 31, 2014 Oh yeah, because the Ork's 5+ cover (NOT invulnerable) save force field makes them nigh unbeatable somehow, I guess. Link to comment Share on other sites More sharing options...
Master Sheol Posted January 31, 2014 Share Posted January 31, 2014 Dont worry shabbadoo... They Will fix it in the next orks codex from cover to 5++... In GW design team the nerf stick carries only the DA badge... We all should Know that GD are players before GD and they Write codices according personal tastes (if Ward loves GK then he Will Write them)... I guess there is no DA fan in the Design studio so they give DA to Vetock (the younger 40k GD) and he rushed the book in Order to work on His beloved Tau... This is why DA are flat normal and tau is OP... ;) Link to comment Share on other sites More sharing options...
Dark Haven Posted January 31, 2014 Author Share Posted January 31, 2014 In GW design team the nerf stick carries only the DA badge... Interesting, you'd think the Dark Angels are the Lamenters. Link to comment Share on other sites More sharing options...
Chaplain Lucifer Posted January 31, 2014 Share Posted January 31, 2014 Straying too much off-topic, gentlemen... Link to comment Share on other sites More sharing options...
