Forté Posted January 28, 2014 Share Posted January 28, 2014 Hi. I'm going to be doing some converting and so far it's always been small things and I've used Kneadatite (green stuff). I'm now looking at doing a few larger things and was wondering if green stuff can be mixed together with Milliput as I have some of both. Link to comment https://bolterandchainsword.com/topic/286186-apoxy-putty-compatability/ Share on other sites More sharing options...
Shadespyre Posted January 29, 2014 Share Posted January 29, 2014 Yes it can. I read about it somewhere a few years ago and tried it - I did 10-20% GS in white milliput - and it set off perfectly well. It ends up with different properties depending on the mix you make, I would have a google around to look for advice on that. I love Milliput - it sets much harder and stiffer than GS and can be sanded, drilled, filed more neatly - but it is messy to use compared to GS. I've always suspected the perfect answer lies in mixing them but I've never really had a project which justified further experiment. Link to comment https://bolterandchainsword.com/topic/286186-apoxy-putty-compatability/#findComment-3581191 Share on other sites More sharing options...
Forté Posted January 29, 2014 Author Share Posted January 29, 2014 Many thanks Link to comment https://bolterandchainsword.com/topic/286186-apoxy-putty-compatability/#findComment-3581380 Share on other sites More sharing options...
Hemal Posted January 29, 2014 Share Posted January 29, 2014 You can get a full spectrum of hardness using different mixes of millput and GS.. Link to comment https://bolterandchainsword.com/topic/286186-apoxy-putty-compatability/#findComment-3581534 Share on other sites More sharing options...
Seleucus Posted January 29, 2014 Share Posted January 29, 2014 Any of these helpful? http://www.coolminiornot.com/forums/showthread.php?30767 http://www.coolminiornot.com/forums/showthread.php?25059 http://www.bananaking.net/cento/workshop/conv_green.htm Link to comment https://bolterandchainsword.com/topic/286186-apoxy-putty-compatability/#findComment-3581546 Share on other sites More sharing options...
Forté Posted January 30, 2014 Author Share Posted January 30, 2014 Those are some great links. Especially the last one. Many thanks. Link to comment https://bolterandchainsword.com/topic/286186-apoxy-putty-compatability/#findComment-3582235 Share on other sites More sharing options...
