Interrogator Stobz Posted February 5, 2014 Share Posted February 5, 2014 ;) For a minute there I thought you were walking your nators up alongside the LRCs, stupid me :P Link to comment Share on other sites More sharing options...
[TA]Typher Posted February 5, 2014 Share Posted February 5, 2014 For a minute there I thought you were walking your nators up alongside the LRCs, stupid me Oh God no. Link to comment Share on other sites More sharing options...
march10k Posted February 5, 2014 Share Posted February 5, 2014 Well, if you're following my list to a tee, you can be DWAing inside the enemy deployment zone (with two squads) scatter-free on turn two, and charging/runnin in with the two mounted squads...and driving in with the two tanks and the bike, lol, getting 1850 points into his deployment zone on turn two...That's if you're all-out-agro, moving 18" on turn one and DWAing 6" in front of the tank that has Belial inside...but I usually take it a little slower and meet the enemy halfway for a rumble in the mid-field. Since I got back to the USA and a much tougher metagame, I'm 2-2 with the list, and none of the four games were close. In my two wins, I left two enemy models on the table both times, in both cases including a flier. In the two losses, I was tabled, once on turn 4 and once on turn 6...I'm stunned that you had a draw with a list as unbalanced as mine...it should be feast or famine! Link to comment Share on other sites More sharing options...
elmo Posted February 5, 2014 Share Posted February 5, 2014 Magnets! Most of my termies are magnetised so that I can swap weapons as required. What he says :) I have magnetised all my termi arms to allow any weapons loadouts I could possibly wish for. It can be a little fiddly till you get the hang of it but when you get 5 sets of both TH/SS and LCs in the assault termi box it is a shame to not use them all. As for which ones to use I cannot really add to the advice already given. Link to comment Share on other sites More sharing options...
Gillyfish Posted February 6, 2014 Author Share Posted February 6, 2014 Thanks Elmo (and Seleucus for that matter). I have considered magnets in the past but I haven't actually tried using them yet - too nervous of ruining the models I suppose! I assume I would also need a dremel to make enough space to insert the magnets? Link to comment Share on other sites More sharing options...
Interrogator Stobz Posted February 6, 2014 Share Posted February 6, 2014 I use 5mm diameter by.5mm thick magnets on mine, tu literally just shave of the little attachment lump on the body and stick them on. They end up looking like the joins between the plates and you can paint the edges to match if you don't like them shiny. Take another peek at mine, they are relatively seamless. Hope that helps. s Link to comment Share on other sites More sharing options...
Larhendiel Posted February 6, 2014 Share Posted February 6, 2014 I just made squad of 5 termies with all weapon options magnetised. I use 3mm magnets inside torso and arms, All I had to do is to get 3mm drill and make 2mm holes inside plastic parts http://i1035.photobucket.com/albums/a437/Larhendiel/Warhammer/DSC03268_zps5f9949e9.jpg http://i1035.photobucket.com/albums/a437/Larhendiel/Warhammer/DSC03269_zps2c8d3363.jpg Link to comment Share on other sites More sharing options...
march10k Posted February 6, 2014 Share Posted February 6, 2014 awesome! I cringe at the thought of doing that, though. It does maximize the flexibility of a limited number of terminators, but who wants just 10-20 terminators! Instead of 3x as many arm pairs (more, including the other special weapons), how about 3x as many terminators, instead? Muahahaha! Actually, even then, magnetizing the heavy weapon terminators makes sense... Link to comment Share on other sites More sharing options...
Pbenner Posted February 6, 2014 Share Posted February 6, 2014 Or 8x as many terminators. ^_^ Link to comment Share on other sites More sharing options...
Seleucus Posted February 7, 2014 Share Posted February 7, 2014 Thanks Elmo (and Seleucus for that matter). I have considered magnets in the past but I haven't actually tried using them yet - too nervous of ruining the models I suppose! I assume I would also need a dremel to make enough space to insert the magnets? Never use a dremel for this - too much lack of control. A simple pin vice will do fine if you stick to plastic or resin models. Link to comment Share on other sites More sharing options...
Pbenner Posted February 7, 2014 Share Posted February 7, 2014 You don't even really need the pin vice for this either. A 1/8" drill bit with some grip tape around the shaft is just as good. Paul Link to comment Share on other sites More sharing options...
Gillyfish Posted February 7, 2014 Author Share Posted February 7, 2014 Cool, thanks gents. I'm not yet sure if I will use magnets for my termies, but I will certainly look into it. Link to comment Share on other sites More sharing options...
