Tubbylove Posted February 3, 2014 Share Posted February 3, 2014 Hi All, I was hoping you guys could help clarify a couple of things for me please. Arjac has his foe hammer. Am I right in thinking that when he throws it and it causes a wound it does not then reduce the enemy to Int 1. The codex only displays assault 1. in the stat line. I read somewhere that it may actually reduce enemy to INT 1 as well, for a cheeky little jaws combo. I have tried looking in the FAQ's but none mention the above. ARJAC has Stubborn, so am I right in thinking that this transfers to his whole unit as well? or just him? as the rule book says anyone in the unit. I am thinking I am getting confused with older editions rather than just 6th for the above These are probably really newb questions but thought I would ask to clarify for myself. so please forgive me. JAWS - does it affect my own units as well if I am the caster? JAWS if it hits a unit in close combat, do they ignore it? (I assume that this is yes) Hurricane if I use this and the enemy unit has ignore terrain, do they continue to ignore the terrain or are they now affected? Again I looked in the FAQ but could not see anything referencing it. Thanks. Link to comment https://bolterandchainsword.com/topic/286413-a-few-questions-to-answer-please/ Share on other sites More sharing options...
Nadir Posted February 3, 2014 Share Posted February 3, 2014 Errata for SW v1.3: Q: Is a model that has suffered an unsaved wound, but hasn't been killed, from Arjack throwing his Foehammer reduced to initiative 1 until the end of the next player turn? A: YES Yes, the stubborn rule is transfered, when anyone in the unit has it. JAWS : - yes it affects your units, but your unit cannot be targeted (you have to chose one enemy model as a target) - units in HtH doesn't ignore it, but cannot be targeted - the unit struck by Hurricane treat the terrain as difficult. If that unit ignore difficult terrain, it will ignore "magicaly difficult" terrain Link to comment https://bolterandchainsword.com/topic/286413-a-few-questions-to-answer-please/#findComment-3585597 Share on other sites More sharing options...
