MadMek83 Posted February 7, 2014 Share Posted February 7, 2014 Hello everyone! Its been couple of after my major stomach area surgery, I have healed enough to actually start new project, as my stomach area muscles, especially abs have healed after surgeon cut thru them leaving me nice 7,5" scar. But to actual point: Morbus Bubonicus. Nurgle's very own lil Helbrute. http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4247_zps5e7d828e.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4243_zpsc6a1f65d.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4244_zps21ad0234.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4241_zpsd365a080.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4245_zps8d4cd9e5.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4240_zpsadd357dd.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4239_zps45e9c06a.jpg There's few things I need to clean before priming. I accidently split multimelta slightly from its seam when I thought Reaper autocannons or multimelta and tested things. I need to fix that seam and clean plastic a tad more. Considering how much Greenstuff this has already taken, I don't think I'll be adding that much Greenstuff, anymore and I might go bankrupt. Anyway, I keep you guys posted. Link to comment Share on other sites More sharing options...
deathspectersgt7 Posted February 7, 2014 Share Posted February 7, 2014 Looks good glad to hear you are healing. Link to comment Share on other sites More sharing options...
Xenith Posted February 7, 2014 Share Posted February 7, 2014 Pfft, doctors. Just pray to Nurgle, he seems to have already gifted you with GS ability. Loving the cable worked into the GS., Its good to see those big smooth areas at the back get some texture! Link to comment Share on other sites More sharing options...
Phalanx Warder Posted February 8, 2014 Share Posted February 8, 2014 try here for cheeper GS http://www.sylmasta.com/acatalog/Kneadatite-Duro--REEL---Green-Stuff--36---90cm--331.html#SID=14 Link to comment Share on other sites More sharing options...
Skrundle87 Posted February 8, 2014 Share Posted February 8, 2014 Very cool stuff Link to comment Share on other sites More sharing options...
Slave to Darkness Posted February 8, 2014 Share Posted February 8, 2014 its beautiful!!! Link to comment Share on other sites More sharing options...
MadMek83 Posted February 21, 2014 Author Share Posted February 21, 2014 There's some progress, but its far from finished. Ome areas have not been touched, others need more rust, others need cleaning and I need to work the skin as it did not turned way I wanted but I think all is not lost yet... ^^ http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4251_zps2439c79d.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4252_zps3c161623.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4253_zps7b5eac2f.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4254_zpsd26ab145.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF4255_zpsbbc8ded7.jpg Link to comment Share on other sites More sharing options...
MadMek83 Posted March 16, 2014 Author Share Posted March 16, 2014 Here's as Bubonicus is now. When I was reåainting skin, I went thru the idea of removing Multi-melta simply as it looked horribly unbalanced. So I quickly converted into infected and mutated powerfist with heavy flamer. Rule of Cool :D http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF6001_zps91a34117.jpg http://i294.photobucket.com/albums/mm103/thejamppa/Miniatures/DSCF6003_zps232dcb1c.jpg Link to comment Share on other sites More sharing options...
