Vile Siren Posted February 25, 2014 Share Posted February 25, 2014 Simple question can you repose FW minis with hot or boiling water and is so how pliable do the minis become after sitting in said boiling water? Any info would be a help. Link to comment https://bolterandchainsword.com/topic/287253-reposing-fw-minis/ Share on other sites More sharing options...
Gunny333 Posted February 25, 2014 Share Posted February 25, 2014 Would not recommend boiling water. After submersion for any period of time that leaves them malleable they stay weakened in the point of whatever pivotal movement is used. Best thing to do is to just cut and reglue. Link to comment https://bolterandchainsword.com/topic/287253-reposing-fw-minis/#findComment-3603197 Share on other sites More sharing options...
Grotsmasha Posted February 25, 2014 Share Posted February 25, 2014 I second cutting, pining and reglueing. I recommend a Hobby Saw rather than a knife as you'll get a cleaner, even cut. Hot water is fine for straightening bent pieces though. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/287253-reposing-fw-minis/#findComment-3603212 Share on other sites More sharing options...
Vile Siren Posted February 26, 2014 Author Share Posted February 26, 2014 Ok good to know before I did something I would regret. Thanks guys for the reply! Link to comment https://bolterandchainsword.com/topic/287253-reposing-fw-minis/#findComment-3603622 Share on other sites More sharing options...
Kaedes Nex Posted February 26, 2014 Share Posted February 26, 2014 Depends on the model. Tartaros are probably thick enough that you can just use the boiling water method. Even boiling water takes a good while for them to soften up enough to bend and are probably thick enough that the integrity issue isn't a problem. Link to comment https://bolterandchainsword.com/topic/287253-reposing-fw-minis/#findComment-3603658 Share on other sites More sharing options...
Vile Siren Posted February 26, 2014 Author Share Posted February 26, 2014 Well it would be the Fulgrim mini from forgeworld and I am sure it may seem stupid to want to repose the mini but I just want to make it a better pose because I am not to found of the dancing dodge he has going on. I understand it works when he is with Ferrus. Link to comment https://bolterandchainsword.com/topic/287253-reposing-fw-minis/#findComment-3603689 Share on other sites More sharing options...
DarkMark Posted February 26, 2014 Share Posted February 26, 2014 Nice easy YT video from on exactly this subject. Link to comment https://bolterandchainsword.com/topic/287253-reposing-fw-minis/#findComment-3604160 Share on other sites More sharing options...
Vile Siren Posted February 27, 2014 Author Share Posted February 27, 2014 Wow that was a lot of help, thank you! Link to comment https://bolterandchainsword.com/topic/287253-reposing-fw-minis/#findComment-3604449 Share on other sites More sharing options...
