Acts of Faith, War Hymns, & Leadership Tests
One for the squad using the AoF and one for the preacher for his War Hymn is what I would think to be correct. Just remember that since the preacher is part of a squad, he can use the squad's highest average Ld for his test.
Well average as in most common value like you do for Toughness on to wound rolls.  Characteristic tests are highest value.
And it is two rolls.  One for each.
For what it's worth, if you have more than one priest, you can retest the same battle hymn if the first one failed.
That's not an average, that's a majority msn-wink.gif With a name like Fibonacci surely mathematics should be your strong suit? laugh.png
Well, you're called WarriorFish and yet you're not even in the Navy :P
But he might be a fish...
Consider litanies of faith upgrade for your priest if you're running several acts of faith/war hymns in a squad.
0,1,1,2,3,5,8 ;)
I never was much into set theory.  Dif-E and linear algebra were more my focus because they related to programming which is what I was most interested in way back then.
Anyway, I was just saying I understood what Ludovic meant.
The sea is in my blood, I don't need to be on it to be connected to it - if I get too far inland I get antsy tongue.png
I agree with Naminé, Litanies of Faith might not be as fun as the old days but it's worth considering for trick squads. Don't worry Fib I was just joking, and perhaps still a little too early into my sugar reduction regime tongue.png Mother always said I was sweet enough, I guess I should have listened to her... laugh.png
Modal average.
Also, if I may 'wade' in here (pun completely intended) there are a number of different types of averaging methods not just the 'mean', which would be what warriorfish is referring too. Perhaps Fibonacci was referring to the 'mode' average, which would indeed be the most common number in a range of numbers. Therefore, Fibonacci would be technically correct (the best kind of correct! smile.png ) in calling it the average (albeit he should have made which average he was referring too clear to begin with).
EDIT:
Curse you Furyou Miko! I didn't read your post!
I can't help it, I'm a Dr of evolutionary biology, stats is an unfortunate constant in my life :p
Sounds a little like the makings of a genestealer cult to me! You should probably roast some xenos vermin to ensure such practices do not devolve into heresy! ;)
I can't help it, I'm a Dr of evolutionary biology, stats is an unfortunate constant in my life tongue.png
Sounds a little like the makings of a genestealer cult to me! You should probably roast some xenos vermin to ensure such practices do not devolve into heresy! msn-wink.gif
Good idea Namine, I see your from Leicestershire, I'm at Leicester University, perhaps you could help me :p
So I might have been playing this wrong all the time! Can the priest acutally use someone elses leadership when attempting to use a war hymn? Also, can a unit use a Cannness leadership when attempting their own act of faith?
Tthe examples above are of course assuming the independent characters have joined a unit of sisters.
Ok heres a buger that i have been trying to hash out.... Lets say my canoness escort (her command squad and a priest or 3) get into combat. The first turn they are granted rerolls from hatred due to the priests zealot. In subsequent combat phases can the canoness use an act of faith to give hatred to the squad and again prompt some rerolls? Sorry if its of topic but it DOES involve leadership tests (unless there is the litnies)
