I'm a Convirgin
tjdudey
Did you see what I did there.
Am quite new to Warhammer, and am loving my Wolves.
However, I want to make my own Long Fang models,
Is it possible to magnetise the standard troop models, so that I can switch between lascannons, missile launchers etc depending on what I want?
Or are those models too small to effectively magnetise?
Would love some tips on this, as well as the uses of Green Stuff.
Thanks
Tom
https://bolterandchainsword.com/topic/287608-im-a-convirgin/
You can definately magnetise power armour..ve never done long fangs though (only my wolf guard are magentised). The one issue with magents you may have in this case is if the heavy weapon is metal, it may weight a bit to much to magentise, but id definately give it a shot
The 2 arms are always connected by the weapon (unless you go oldskool) so you hve to slide the wapon on from the front, it can be done but there is a big chance of damage. I wouldnt bother and just make the models, its not like you need 50 of them
If you want to magnetize them I would hunt around for the older LF kit, from the late 90s... their heavy weapons being on a single arm would allow for that level of customization easy. Alternatively you could kitbash with some IG heavy weapons, which are often just a wee bit smaller and look fine one handed by a marine.
Thanks for all your advice, I especially like the idea of kitbashing these, I would like some fairly unique models.
I will give this a go.
Tom
