Ultramarine vet Posted March 10, 2014 Share Posted March 10, 2014 So if a vehicle suffers an immobilized result and loses a hull point, and It Will Not Die is successful, is it no longer immobilized as well as regaining the hull point? Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/ Share on other sites More sharing options...
Azash Posted March 10, 2014 Share Posted March 10, 2014 Still immobilized but it gets its hull point back. The rule only mentions the hull point being regained. It makes no mention of the effect being reversed. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616200 Share on other sites More sharing options...
Grey Mage Posted March 10, 2014 Share Posted March 10, 2014 No, it simply doesnt have that particular HP damage. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616201 Share on other sites More sharing options...
Dam13n Posted March 10, 2014 Share Posted March 10, 2014 Yep, It will not die on vehicles is effectively hull point regeneration, that's all. Damage results other than a lost hull point are unaffected. It's still pretty handy to have though. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616497 Share on other sites More sharing options...
netminder69 Posted March 10, 2014 Share Posted March 10, 2014 But if it also has Power of the Machine Spirit (I think that's the right one) you can not shoot and make a separate roll to end the immobilized. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616552 Share on other sites More sharing options...
Morollan Posted March 10, 2014 Share Posted March 10, 2014 But if it also has Power of the Machine Spirit (I think that's the right one) you can not shoot and make a separate roll to end the immobilized. I think you must have the name wrong. PotMS has no effect on HP recovery. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616571 Share on other sites More sharing options...
Dam13n Posted March 10, 2014 Share Posted March 10, 2014 I think you (netminder) mean the Repair special rule that Rhino transports have. They get to sacrifice their shooting phase to make a repair roll (that suceeds on a 6) to remove an immobilised result. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616593 Share on other sites More sharing options...
JamesI Posted March 10, 2014 Share Posted March 10, 2014 It would be great if It will not die could cure Immobilized or weapon destroyed. But just HP regen is pretty good too Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616601 Share on other sites More sharing options...
Ultramarine vet Posted March 10, 2014 Author Share Posted March 10, 2014 Thank you all for the info! Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616847 Share on other sites More sharing options...
Lord Tarkin Posted March 10, 2014 Share Posted March 10, 2014 I think its stupid though. Its dumb that you can become a perfectly healthy vehicle...but still retain damage. Its ridiculous. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3616993 Share on other sites More sharing options...
alex567 Posted March 10, 2014 Share Posted March 10, 2014 I dont think its reference to a perfectly healthy vehicle, more so to sustaining damage then as in the case of a forgefiend for instance renitting the holes where the damage has taken place, yet still having the main component damaged. For a rhino repair roll the reverse is true, a chunk is blown out of the tank, but the crew manage to get it going again, the hole is still there the tracks just work around it as all. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3617010 Share on other sites More sharing options...
Ultramarine vet Posted March 10, 2014 Author Share Posted March 10, 2014 I dont think its reference to a perfectly healthy vehicle, more so to sustaining damage then as in the case of a forgefiend for instance renitting the holes where the damage has taken place, yet still having the main component damaged. For a rhino repair roll the reverse is true, a chunk is blown out of the tank, but the crew manage to get it going again, the hole is still there the tracks just work around it as all. Whoa. I thought I got hacked until I saw your name. :D Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3617031 Share on other sites More sharing options...
alex567 Posted March 10, 2014 Share Posted March 10, 2014 All us ultramarine look the same. Imperial STC's at their finest. We took a leaf from the alpha legion from that one. "I am Guilliman and so's my wife!" Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3617036 Share on other sites More sharing options...
Ultramarine vet Posted March 10, 2014 Author Share Posted March 10, 2014 That my good sir, is too funny. Link to comment https://bolterandchainsword.com/topic/287844-it-will-not-die-special-rule/#findComment-3617039 Share on other sites More sharing options...
