Priests in Repentia
They don't have Hatred natively, and Rerolls to wound are useful. The Priest could also let them reroll their invulnerable, so they have a rerollable 6++ then their 3+ FnP.
Losing Fleet is a pain, but you can always have the Priest assault separately.
Alternatively, if you don't have him assault separately, you can use his 4++ rosarius save to tank any lucky overwatch shots if you want to keep the Mistress' power whips alive.
That way, if he dies, you can suddenly re-roll your assault distance anyway :P
I can't help but feel as though it starts to tack a few too many points onto the Repentia for too little gain, however, it is something I've yet to try and I think it could work, especially if you go the Rhino/Repressor route for the Repentia.
I will try it out in the future though :p
Thanks for the replies.
My biggest idea was to reroll FNP (I mistakenly thought FNP was treated like an invul save). But since that's off the table, I think I'll move him somewhere else. Not sure where though
A battle conclave is always a good spot.  Failing that, even a unit of Battle Sisters with an extra priest becomes a pretty big threat in CC.
i have started collecting repentia finally after several years of playing sisters. They are imo one gee dubs best sculpts to date. It's exactaly what the should be, stripped of all honor and in agony. These and the pen engine (which falls afart when i look at it) are superb. The only priest i've ever put in the squad was jacobs as he can make them more survivable enough to justify the lack of fleet.
If you do run  a priest with them, put them in a Rhino! Protects the unit and takes care of fleet. Plus it allows the unit to get close enough for the girls to get into combat! It seems like any time I see or run repentia, the other side throws every shot they can at them! Like they think that they are that bad! I don't even use them to go after infantry! I use them to take out tanks or termies! When you go after vehicles Int. doesn't count and when you go after termies, most of the time its the same Int.! And at even a two for one cost you win! Cause if you are trading two repentia for each termie you are winning the combat!
