Battlefoam question
The chassis is the same so it'd just be a matter of the cannon. From the picture it already has a section cut out for an extended barrel to the front of the tank so I don't think it should be a problem. Hopefully someone has both so they can give you a definitive answer, failing that there's always the option of attacking it with a knife?
Does (IG) 2 Baneblade Foam Tray (IG08BF-5)
fit a shadowsword?
Any chance I could get a photo with a banebalde and/or shadow sword in that?
Considering a purchase....
Happen to have 2 of these, and YES, it does fit a shadowsword nicely. You'd have to remove the sponsons for an even fit for both tanks, but there's plenty of space in the front to put them.
