Helfist Murderpack
Anybody interested in talking about building a firepower list starting from the Murderpack?
My initial thoughts have been:
Crimson Slaughter Primary
HQ
Sorcerer - Balestar of Mannon, ML3
Troops
30 Cultists - 26 Autoguns, 3 Flamers
10 Cultists
10 Cultists
More?
Less?
Elites
3 Helbrutes - Reaper Autocannons
Fast Attack
Heavy Support
Obliterators?
Forgefiends?
Maulerfiends?
Defilers?
Murderpack Detachment
Reaper Autocannons
Missile Launchers or Plasma Cannons
Daemons Allies ?
HQ
Herald of Tzeentch - Mastery Level 3, Locus of Conjuration
Troops
10 - 20 Horrors
Elites
Flamers ?
Heavy Support
Soul Grinder ?
Seeker Cavalcade ?
I think the biggest decision comes from the HS choice primary. Do I go the utility of Obliterators? Or the speed and tank busting power of the Maulerfiends? Or then again I could follow the theme and have the added firepower and range of Hades Forgefiends and/or Defilers? What about advancing Ectofiends and Plasma Helbrutes? Is more AV the key to this build?
Could I do it better with a Daemons Primary supported by Soul Grinders? Or would mass Slaanesh chariots compliment the range of the brutes ?
https://bolterandchainsword.com/topic/288693-helfist-murderpack/
I'm certainly curious.  My estimation of the murderfist has risen along with my skepticism of the mayhem pack.  Not to the point that I think it's worthwhile, but to the point that I'd certainly like to see someone try to make it work.
The issue is points cost, though.  You're HQ will be, what, 150 points (and while divisorc is obv superior, I'd be sorely tempted to go smith on this one, for thematics if nothing else)?  Even min troops is another 100, then nearly 600 points of murderfist (assuming missile launcher & reaper minimum), so that's already 850 points, with only min primary slot.  Want three more brutes for some reason?  300+ more points?  A pair of drakes?  You're already talking 1500 points, and it really doesn't feel like a 1500 point list to me.  Among other things, you've still only got min cultists for troops, and if that's your only scoring, imo that's really asking for trouble.  Try and throw in another big unit of cultists, oblits or fiends, and allied daemons, and you'll be looking at a list well over 2k points before you even know what's happening.
How about a rough starting point - I'll say 2000 points which is my standard game size
Sorcerer
Balestar
Mastery 3
Warpsmith
Cultists x 30
26 Autoguns
3 Flamers
Cultists x 13
Cultists x 13
Cultists x 13
Cultists x 12
3 Helbrutes with Reaper Autocannons
2 x Maulerfiends
Obliterators x 2
Helfist Murderpack
5 x Helbrutes with Missile Launchers and Reaper Autocannons
To me the Murderpack definitely seems to be the worst of the dataslates, because of a few things.
First off, sure, you get to pick the crazed result you want, but it only affects the Helbrutes with crazed markers (meaning only one, two tops will get to fire twice), and if you do pick the 'fire twice' result, all your five dreads have to shoot at the same target, which has to be whatever shot your dread. How often do you want to target the same thing with five dreads?
So if you instead go with a close combat approach, you have the same situation. If you pick Blood Rage, your dreads with crazed markers get fleet, but since the whole squad wont have it, they will not benefit anyway.
Really, the only thing Pack Leader does is ensure you don't get Blood Rage on your shooty dreads. And even if you always pick Rising Fury, you are still stuck with having to target the same thing with all your five dreads.
Of course, it could be pretty good when the pack it down to 2 dreads maybe, but I just do see the point of the formation? Helcult allows the dread to work in support of infantry, Mayhem Pack allow Dreads a means of deployment that allows them to participate in the battle in a meaningful way, but I don't see what the Murderpack is supposed to do (except cost a whole lot of points)?
@Ammonius: What load out would you go for that brute? Could be a good idea, might try to write it in
Another way I looked at doing the list was this:
Warpsmith
Burming Brand
Warpsmith
Helbrute
Reaper Autocannon
Helbrute
Reaper Autocannon
Helbrute
Reaper Autocannon
20 x Cultists
2 x Flamers
20 x Cultists
2 x Flamers
10 x Cultists
10x Cultists
Dakkafiend
Dakkafiend
Defiler
5 x Helbrutes
Reaper Autocannon
Missile Launcher
Actually, with that list there is literally zero reason not to make one of those brutes a helcult leader.  You should probably even drop one of the remaining cultist units, and reduce squad size on the others, to bulk up your second fearless squad in the cult.
Alternatively, split the bigger cultist unit in half, and make two of your remaining brutes cult leaders, for 4 small fearless cultist squads, plus 2 dreads with 3+ cover?  Maybe drop the last dread to bulk out the cultists?  I like the divisorc, but I could see runing skyshield instead, maybe?  Maybe lascannons on the dreads, as an excuse to drop the oblits?
How about this:
Black Legion
Smith, eye of night
2x10 cultists
Baledrake
Dakkafiend
Skyshield Landing Pad
Helcult
- Brute; lascannons, scourge
- 25 cultists, 2 flamer
- 10 cultists
Helcult
- ditto
Helfist
- 5xlascannon, 5xmissile
By my count that's 2k on the nose?  I don't completely hate the look of that, but it still doesn't look like 2k points to me.
if your going to run engines, particularly forge fiends you really need that Div3 Sorcerer. just the rerolls potential alone is necessary for your BS3 machines
Do the cultists remain scoring if taken as a formation?
yes....can we get this stickied somewhere I'm tired of people asking the same damned thing
I'm going to give a few of these ideas a go. Skyshield and the brutes on top sounds good I reckon.
In other news playing a doubles 2000 point (1000 each, selected rules allowed - no forgeworld, no escalation, no AV15, supplements and data slates allowed) tourney next month, allying with a Farsight crisis suit spam and I am thinking of taking the Helfist and the Skyshield, not taking it too seriously with my choice but could be worth a laugh, what else should I squeeze into this?
The choice will probably be div sorcerer or landing pad and warpsmith.
I think for arguments sake i'll look at
Warpsmith
3  x 10 Cultists
Skyshield
5 x Helbrutes with Reaper Autocannon and Missile Launcher
90 points to spend. Haha it's very light. I could bulk up on the Cultists or change the armament on the brutes, maybe a 2nd cheap HQ. But very very light
How are you equipping the helfist at only 550? If going for long range firepower (which you need to do if you want to run them static on a landing pad), then 550 covers the missile launchers only, with no main guns other than heavy bolters or multi meltas, neither being very good for ranged support. The minimum you should want to use there is reaper autocannons, which pushes the price up to, iirc, 575, and even then the range isn't great, and your partner will need to be able to handle heavy armor, infantry and vehicle. Imo, the ideal would be lascannons, but they you're looking at fully 675 points for the squadron.
Range as much as anything else leads me to push for lascannons on a static helfist meant for support fire.  I'd be more comfortable with the autocannons on them if they were regular twin linked autocannons like the loyalist version instead of the shorter ranged reapers.
