A Son of Sanguinius Posted March 31, 2014 Share Posted March 31, 2014 Hi all, I have been thinking of using weathering powders for rust effects. Is there a brand anyone really likes? More importantly, is there a brand anyone really hates? Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/ Share on other sites More sharing options...
Hemal Posted March 31, 2014 Share Posted March 31, 2014 Mig powders seem to be the way to go, but Vallejo are also pretty good Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/#findComment-3638944 Share on other sites More sharing options...
Honda Posted March 31, 2014 Share Posted March 31, 2014 I've heard good things about Vallejo and I use Mig, so would recommend both. I have not heard anything about Secret Weapons though I'd be interested in hearing about them. Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/#findComment-3639236 Share on other sites More sharing options...
Secretpaintgeek Posted April 1, 2014 Share Posted April 1, 2014 I use pastels from art shops and just scrape them with a sharp blade. Pretty cheap and having a few colours means that I can mix various ones to create more depth/realism to it. Just be sure to get a decent quality one so it isn't 90% binder and they work a treat. Never tried any of the branded ones though but have heard good things about Mig Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/#findComment-3640230 Share on other sites More sharing options...
Iron-Daemon Forge Posted April 1, 2014 Share Posted April 1, 2014 I use Forge world weather powder & MIG pigment fixer to seal the powder onto the models. IP Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/#findComment-3640233 Share on other sites More sharing options...
PhantomPhixer Posted April 1, 2014 Share Posted April 1, 2014 Have to ditto the pastel sticks from art shops. Gazillions of colors, you can make your own custom mixes and a stick will last you a lifetime. Way cheaper. use the same methods to fix them in place (Any brand pigment fixer.) You can also mix them with acrylic medium to "flow" them into places, or get a clumping effect. Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/#findComment-3640323 Share on other sites More sharing options...
Tyrannicide Posted April 2, 2014 Share Posted April 2, 2014 Ak Interactive, and the actual powders are basically the MIG stuff reincarnated, from what I've heard. Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/#findComment-3640718 Share on other sites More sharing options...
Honda Posted April 3, 2014 Share Posted April 3, 2014 So this "pigment fixer" you guys mention, what is it made of? I've just been using Isopropyl Alcohol or Futures' (depending on the need). Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/#findComment-3641652 Share on other sites More sharing options...
Ramell Posted April 4, 2014 Share Posted April 4, 2014 I've used Forge World's powders for a while, and I recently started using Vallejo's Pigment Binder. Never tried anything else, so I can't compare it, but it works just fine for me. So this "pigment fixer" you guys mention, what is it made of? I've just been using Isopropyl Alcohol or Futures' (depending on the need). Depends on the manufacturer. Vallejo's is a water-based acrylic. Link to comment https://bolterandchainsword.com/topic/288889-which-weathering-powder-to-use/#findComment-3642943 Share on other sites More sharing options...
