Alpha Legion 1500
This is my first (shopping) list. I will play it almost exclusively against 40k armies.
USR: Infiltrate
Legion Praetor (Cataphractii) 160
w/ Paragon Blade, Power Dagger
Lernaean Terminator Squad 225
Contemptor-Mortis Dreadnought 180
w/ Twin Kheres Pattern Assault Cannon
Legion Tactical Squad 235
w/ +5 men, Legion Vexilla, Artificer Armour, Power Fist
Legion Sicaran Battle Tank 175
w/ Lascannon Sponsons
Legion Heavy Support Squad 290
w/+5 men, Missile Launchers, Augury Scanner
TOTAL
1500
What do you think?
Edit: I did a complete overhaul (really wanted to free that elites slot for 'The Rewards of Treason' in 1750/1850 or 2000)
https://bolterandchainsword.com/topic/288928-alpha-legion-1500/
Don't forget to check out some vexilla's for your tactical squads, and artificer armour for your apothecaries if you are able to find the points.  What's the power dagger on your praetor?  Seems obsolete considering you have a paragon blade.
Otherwise it looks like a nice start into 30k :)
Glad you like it. Power dagger is s: user-1 ap3 rending, specialist weapon for half the price of power sword (which can be taken in addition to any other weapons). So it's basically super cheap +1A for Praetorbiggrin.png
If I am right, whilst the Praetor starts with both a Bolt Pistol and Chainsword/Combat Blade, he replaces one of them with the Paragon Blade.  The Paragon Blade has the Specialist Weapon rule - as does the Power Dagger (I assume, I haven't read the rules on this item).  Therefore allowing the model to have +1 for an additional CCW as both are specialist weapons.
Is that correct?
Is that correct?
Yup. That's exactly what I meant.
I thought with specialist weapons it required two of the same sort of weapon to gain the +1 attack. Such as with powerfists.
Specialist Weapon entry in Rulebook says nothing about them being the same - it's just 'both weapons have the S. W. rule'.
As absurd as the rule sounds, the OP is right:
"Specialist Weapon
A model fighting with this weapon does
not receive +1 Attack for fighting with two weapons unless both weapons have the Specialist weapon rule."
It's also not amended in the FAQ...
...dammit, ninja'd... by not refreshing my screen...
