Airbrushing
Ada
Hi,
Ok so I like the idea of trying out a airbrush, the good gear is pricy and I don't want to splash out yet before trying my hand at it on some old models.
So, I've got a cheap airbrush, £10 with a couple of pots and a connecting pipe, and a canister of compressed air, dirt cheap I know and I'm not expecting too much.
Connected everything up, I get some air flow, but there doesn't sound like a great amount of pressure and no sign of any paint coming through.
As far as the set up goes I think it's all right, (how hard can it be) connect the pipes each end and off we go right?
Checked flow through all individual parts by blowing into water, I get bubbles so I'm happy there are no blockages anywhere.
So, issues are, low pressure, no paint flow.
Could this just be down to my cheap as chips set up?
Or, are there some pointers anyone can give me?
https://bolterandchainsword.com/topic/289343-airbrushing/
Do you know anyone that has a compressor that you could hook up to even for a few minutes to test it on?  It sounds like you have air flow issues.  The compressed air canisters are bad for that.  In the end if you like airbrushing you will spend less by getting a compressor.  Unless you need it to be super quiet you can pick them up cheep at hardware stores.
https://bolterandchainsword.com/topic/289343-airbrushing/#findComment-3648643
Cheers for the quick response fellas.
After posting I went back to the setup and had a little play, and I've now experienced a little success!!!!
It seems that I was a little over zealous in connecting the pipe to the compressed air can (wouldn't have thought it could be too tight???). However after slackening it off a tad the pressure noticeably increased from the nib of the brush, so I attached the paint pot again and I now have some airbrush action going on!!!!
@greendestiny, no unfortunately I do not, which is a real shame right now. But it looks like you were right about airflow, and as I've found out it's not just the can which is a little ropy in my setup lol
Quite pleased with my first attempts though.
Any advice on thining paint guys? Currently I'm using water, which to all intents and purposes is working fine, but I'm keen to hear any advice.
https://bolterandchainsword.com/topic/289343-airbrushing/#findComment-3648712
I used water for a long time but ended up trying the Vallejo airbrush thinner some time ago and I personally find I have an easier time getting good coverage and just fewer problems in general.  It is personal preference though, some people find different things easier to work.  I find that more often than not a 1:1 ratio of paint to that thinner is what I use and serves as a good starting point for thinning.
https://bolterandchainsword.com/topic/289343-airbrushing/#findComment-3648762
I use a 4:1 solution of water and clear acrylic floor shine to thin my paints. I can't remember for the life of me what it's called now because they changed the label. It works really well for me.
As for low pressure from canned air, try setting the can in a bowl of warm water to keep it from getting cold and losing pressure. Just don't let it sit for too long without spraying or the pressure inside can build up too much.
https://bolterandchainsword.com/topic/289343-airbrushing/#findComment-3648812
honestly those cheap sets really are not worth it.   Ebay a cheap second hand compressor and a chinese airbrush.  You could get going without a huge investment.   Those cans of air are expensive,  useless and dont last very long so become even more expensive the more you use them.
https://bolterandchainsword.com/topic/289343-airbrushing/#findComment-3649330
