Grand Master Aldric Posted April 12, 2014 Share Posted April 12, 2014 So have a space wolf fail cast captain and because i don't play space wolfs i need to remove the chapter badge and there are several problems. 1: I'm no good at round filing. 2: It is a really small so one might mess up the chain sword trying to file it. And 3: when you go at the badge you properly hit the rest of the pad. So as you can see I'm in a bit of a pickle. http://i1316.photobucket.com/albums/t620/SAKAGE1/m1240774_99060101251_SWcaptainwo-1_zps3b4e3dbf.jpg Link to comment https://bolterandchainsword.com/topic/289421-removing-the-chapter-badge-on-fine-cast-wolf-captain/ Share on other sites More sharing options...
Brother-Chaplain Kage Posted April 12, 2014 Share Posted April 12, 2014 Very carefully cut the hand off on either side of the wrist so you're able to deal with the pad without damaging the chainsword. I would scrape most of it with a hobby knife first, then sand it smooth, and it's much easier to do with finecast than metal. Then glue the hand back on. Also, I never noticed how much that looks like an Eldar chainsword until now. Link to comment https://bolterandchainsword.com/topic/289421-removing-the-chapter-badge-on-fine-cast-wolf-captain/#findComment-3650216 Share on other sites More sharing options...
Grand Master Aldric Posted April 12, 2014 Author Share Posted April 12, 2014 Very carefully cut the hand off on either side of the wrist so you're able to deal with the pad without damaging the chainsword. I would scrape most of it with a hobby knife first, then sand it smooth, and it's much easier to do with finecast than metal. Then glue the hand back on. Also, I never noticed how much that looks like an Eldar chainsword until now. Yeah.. yeah I suppose that could work thanks. as for the eldar thing you know being a space wolf it just might be a eldar chain sword. And hey! that's a good idea you know captain garled could have an eldar chain sword fitting in with the blood hound xenos pact, which helps since i was baffled what to do since both my sergeants have better weapons. Link to comment https://bolterandchainsword.com/topic/289421-removing-the-chapter-badge-on-fine-cast-wolf-captain/#findComment-3650223 Share on other sites More sharing options...
Forté Posted April 12, 2014 Share Posted April 12, 2014 With Finecast you can just breath on it so a little while and parts fall off so if you use a straw you should be able to remove it in no time. Link to comment https://bolterandchainsword.com/topic/289421-removing-the-chapter-badge-on-fine-cast-wolf-captain/#findComment-3650428 Share on other sites More sharing options...
