conscripts better than guardsmen
Hi all
Just checking out the new codex and conscripts seems stupidly good for their points. Basically same as a guardsman but nearly half the cost. Also is actually more likely to hit with his lasgun when point for point compared.
30 conscripts = 90points. Would hit 12 times on average.
18 guardsman = 90 points would hit 9 times.
What could I use for models though?
https://bolterandchainsword.com/topic/289639-conscripts-better-than-guardsmen/
I wouldn't say conscripts are necessarily better per se, however they are certainly better in some applications. It depends on what you are doing with them.
One important thing to keep in mind is that conscripts cannot bring special weapons. So, compare for example:
20 guardsmen with two meltaguns = 120
40 conscripts = 120
However, those 20 guardsmen have a 50/50 chance (better with certain orders) of hitting and then potentially bringing down anything from a rhino to a Land Raider within 6". The conscripts couldn't even scratch the paint on any vehicle. So in certain scenarios guardsmen will be better, in others conscripts.
Also, you can't really compare conscripts to guardmen 1:1 ... because conscripts need a commissar and/or priest(s) to prevent them from fleeing the board at the slightest provocation considering their Ld 5 (versus 8 for guardsmen) plus they can't realistically take orders without a commissar too. So that must be factored in. Not saying conscripts are bad -- I think they've been greatly improved -- but they are different.
If you're thinking purely in Lasgun terms, maybe, but you've also got the considerations of the amount of room they take up and special weapons as mentioned. They could provide a useful role in a list certainly but I don't think the Guardsman needs to fear for his job quite yet :P
Conscripts have no options, including special and heavy weapons, and you can only take one squad per infantry-platoon.
Conscripts are really good at their job (being cheap tarpits), especially when you add in a priest or a commissar, but they shouldn't really be compared to regular guardsment. Apples and Oranges and all that...
