Armored company
Sohail187
So after using pods for so long! i thought id give the razorback / rhino a try!! and just finished my 4 razobacks / rhinos and a damocles. Thought id share and see if any one else has a bunch of these done. Would love to see patterns and schemes of fellow members of the pack.
http://i62.tinypic.com/2du9li1.jpghttp://i61.tinypic.com/551kc3.jpg
http://i62.tinypic.com/2dqr6mh.jpg
Those big tacks in the top right legion fellblade :D just finished making that and looking to add this to my armored company!
https://bolterandchainsword.com/topic/289873-armored-company/
Of course they do. But the opponent will not shoot other targets that way. And if he will ignore the razorbacks, they will make some havoc.
I agree that even though they did drop like flies my scoring units have been staying alive loads more.
And, that's what counts the most, isn't it?
You're thinking of the clause "look ace while doing it" Pg.165 BRB, Val.
End of Line
I love the weathering effect. What method did you use?
the weathering is fairly simple mate. Mig black soot for the exhausts... just dab it in the brush and brush in the directions you want. And the rust is vallejo just a redish red sand color. However to set the pigments its important you use rubbing alcohol. So for example brush the pigments on.... and then use a chunky brush, dip it into the alcohol and just lightly touch all pigmented area and let it dry. Do this twice before you matt varnish, and this will ensure the pigments never come off.
Sohail187, on 26 Apr 2014 - 13:50, said:snapback.png
AHHHMEN!!!
  • 3 weeks later...
Finally managed to finish that fellblade which was hidden in the back round!!!!! However i made a slight OPSEY!!! with the weathering on the front hul... not noticing the brush was in my mouth!! so it was wet when using the powders which has given it that stupid smudge :( CRY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://i62.tinypic.com/2nsluty.jpg
http://i60.tinypic.com/2h81w1v.jpg
http://i61.tinypic.com/33uybdh.jpg
http://i62.tinypic.com/9kv5h0.jpg
